Can some please let me how to Install Okular on Ubuntu 12.04 and also KParts Plugin by command prompt or if you can please let me know any ppa's to install it
Already tried
sudo apt-add-repository ppa:kubuntu-ppa/backports
sudo apt-add-repository ppa:kalakris/okular
sudo apt-get update
sudo apt-get install okular
okular:Depends: libkio5 but it is not going to be installed
       Depends: libkparts4 but it is not going to be installed
       Depends: libkprintutils4 but it is not going to be installed
       Depends: libokularcore4 (= 4:4.13.2-0ubuntu0.1~ubuntu12.04~ppa1) but it is not going to be installed
       Depends: libphonon4 (>= 4:4.7.0really4.3.80) but it is not     installable
       Depends: libpoppler-qt4-3 (>= 0.18) but it is not installable
       Depends: libqca2 (>= 2.0.2) but it is not installable
       Depends: libqimageblitz4 (>= 1:0.0.4) but it is not installable
       Depends: phonon but it is not installable
Let me know what needs to be done.
Thanks in advance.
Sooraj Soman
  • 1,111
Rshrth
  • 185
Both okular and kpartsplugin are in the Ubuntu repositories for Ubuntu 12.04, so you didn't need to add the two PPAs to install them. If you don't need the two PPAs for any other reason they can be removed, and then just install okular and kpartsplugin in the usual way.
From the terminal run:
sudo apt-add-repository --remove ppa:kubuntu-ppa/backports
sudo apt-add-repository --remove ppa:kalakris/okular
sudo apt-get update
sudo apt-get install okular kpartsplugin
karel
  • 122,292
  • 133
  • 301
  • 332
