13
In below function with 9 arguments:
SUM() {
    echo "The sum is $(($1+$2+$3+$4+$5+$6+$7+$8+$9))"
I want to make the second arguments to the next(3..9) become a optional arguments.
When I call the function with 2 arguments I get error:
SUM 3 8
bash: 3+8+++++++: syntax error: operand expected (error token is "+")
Note BOLD: first argument and second argument are force arguments and not optional for function. I only want second arguments to the next is optional and when I call the function less than 2 args the function must return no result.
αғsнιη
  • 36,350
7 Answers7
22
If you won't pass arguments with spaces:
sum() {
[[ -n $2 ]] && echo $(( $(tr ' ' '+' <<<"$@") ))
Effect:
$ sum 1 2 3
Explanation:
  1. <<<"some string" feeds in only "some string" as the input. Think of it as shorthand for echo "some string" |. It is called a Here String.
  2. "$@" expands into all the positional parameters, separated by spaces. It is equivalent to "$1 $2 ...".
  3. Hence, tr ' ' '+' <<<"$@" outputs "$1+$2+$3...", which is evaluated by the outer $(( )).
  4. [[ -n $2 ]] tests if the second parameter is non-empty. You could replace [[ -n $2 ]] && with [[ -z $2 ]] ||.
Another way:
sum() {
[[ -n $2 ]] && (IFS=+; echo $(( $* )))
Explanation:
  1. $* is just like $@, except that the parameters are not separated by spaces, but by the first character of the Internal Field Separator (IFS). With IFS=+, it expands to "$1+$2+...". See What is the difference between $* and $@?
  2. We set IFS in a subshell (note the surrounding parentheses) so that the main shell isn't affected. IFS is, by default: \t\n (space, tab, newline). This is an alternative to using local variables.
Now to answer your question:
You can use a default value for any variable or parameter. Either:
SUM() {
 echo "The sum is $(($1+$2+${3:-0}+${4:-0}+${5:-0}+${6:-0}+${7:-0}+${8:-0}+${9:-0}))" || false
Or:
SUM() {
 echo "The sum is $(($1+$2+${3:=0}+${4:=0}+${5:=0}+${6:=0}+${7:=0}+${8:=0}+${9:=0}))" || false
muru
  • 207,228
17
Have a look at the shift operator. It will shift arguments 2 and onward to positions 1 and onward, discarding argument 1.
sum () {
    local total=0;
    while [ $# -gt 0 ]; do
        total=$(($total + $1))
        shift
    done
    echo $total
zwets
  • 12,770
  • 37
  • 46
You could use a recursive definition which terminates when sum is invoked without arguments. We make use of the fact that test without arguments evaluates to false.
sum () {
    test $1 && echo $(( $1 + $(shift; sum $@) )) || echo 0
zwets
  • 12,770
  • 37
  • 46
Try this:
SUM () {
 [ $# -lt "2" ] && return 1
 for par in $@; do
   local sum=`expr $sum + $par`
 done
 echo $sum
 return 0
SUM 3 4 5
SUM 3 4 5 1 1 1 1 2 3 4 5
This will output 12 and 30.
$@ refers to parameter, $# returns the number of parameter, in this case 3 or 11.
Tested on linux redhat 4
Lety
  • 6,089
  • 32
  • 38
You could just use a little loop:
sum(){
    t=0;
    for i in "$@"; do t=$((t + i )); done
    echo $t;
Personally though, I'd just use perl or awk instead:
sum(){
 echo "$@" | perl -lane '$s+=$_ for @F; print $s'
or
sum(){
 echo "$@" | awk '{for(i=1; i<=NF; i++){k+=$i} print k}'
terdon
  • 104,119
Use 0 as default values for $1 to $9:
SUM() {
    echo "The sum is $((${1:-0}+${2:-0}+${3:-0}+${4:-0}+${5:-0}+${6:-0}+${7:-0}+${8:-0}+${9:-0}))"
From man bash:
${parameter:-word}
    Use Default Values. If parameter is unset or null, the expansion
    of word is substituted. Otherwise, the value of parameter is
    substituted.
Examples:
$ SUM
The sum is 0
$ SUM 1 2
The sum is 3
$ SUM 1 1 1 1 1 1 1 1 1
The sum is 9
Same output with awk:
SUM() {
  echo -e ${@/%/\\n} | awk '{s+=$1} END {print "The sum is " s}'
Cyrus
  • 5,789
It's also my own solution I tried it and found:
SUM() {
    echo "The sum is $(($1+$2+$[$3]+$[$4]+$[$5]+$[$6]+$[$7]+$[$8]+$[$9]))"
$ SUM 4 6 5
The sum is 15
But @muru's answer is good.
αғsнιη
  • 36,350
