14
I want to use find to find files in a set of folders restricted by wildcards, but where there are spaces in the path name.
From the command line, this is easy. The following examples all work.
find  te*/my\ files/more   -print
find  te*/'my files'/more  -print
find  te*/my' 'files/more  -print
These will find files in, for example, terminal/my files/more and tepid/my files/more.
However, I need this to be part of a script; what I need is something like this:
SEARCH='te*/my\ files/more'
find ${SEARCH} -print
Unfortunately, whatever I do, I don't seem to be able to mix wildcards and spaces in a find command within a script. The above example returns the following errors (note the unexpected doubling of the backslash):
find: ‘te*/my\\’: No such file or directory
find: ‘files/more’: No such file or directory
Trying to use quotes also fails.
SEARCH="te*/'my files'/more"
This returns the following errors, having ignored the meaning of the quotes:
find: ‘te*/'my’: No such file or directory
find: ‘files'/more’: No such file or directory
Here's one more example.
SEARCH='te*/my files/more'
As expected:
find: ‘te*/my’: No such file or directory
Every variation that I've tried returns an error.
I have a workaround, which is potentially dangerous because it returns too many folders. I convert all spaces to a question mark (single-character wildcard) like this:
SEARCH=${SEARCH// /?}       # Convert every space to a question mark.
This is the equivalent of:
find te*/my?files/more -print
This returns not only the correct folders but also terse/myxfiles/more, which it's not supposed to.
How can I achieve what I'm trying to do? Google has not helped me :(
αғsнιη
  • 36,350
Paddy Landau
  • 4,658
The exact same command should work fine in a script:
#!/usr/bin/env bash
find  te*/my\ files/ -print
If you need to have it as a variable, it gets a bit more complex:
#!/usr/bin/env bash
search='te*/my\ files/'
eval find "$search" -print
WARNING:
Using eval like that is not safe and can result in executing arbitrary and possibly harmful code if your file names can contain certain characters. See bash FAQ 48 for details.
It's better to pass the path as an argument:
#!/usr/bin/env bash
find "$@" -name "file*"
Another approach is to avoid find altogether and use bash's extended globbing features and globs:
#!/usr/bin/env bash
shopt -s globstar
for file in te*/my\ files/**; do echo "$file"; done
The globstar bash option lets you use ** to match recursively:
globstar
      If set, the pattern ** used in a pathname expansion con‐
      text will match all files and zero or  more  directories
      and  subdirectories.  If the pattern is followed by a /,
      only directories and subdirectories match.
To make it act 100% like find and include dotfiles (hidden files), use
#!/usr/bin/env bash
shopt -s globstar
shopt -s dotglob
You can even echo them directly without the loop:
echo te*/my\ files/**
terdon
  • 104,119
How about arrays?
$ tree Desktop/ Documents/
Desktop/
└── my folder
    └── more
        └── file
Documents/
└── my folder
    ├── folder
    └── more
5 directories, 1 file
$ SEARCH=(D*/my\ folder)
$ find "${SEARCH[@]}"
Desktop/my folder
Desktop/my folder/more
Desktop/my folder/more/file
Documents/my folder
Documents/my folder/more
Documents/my folder/folder
(*) expands into an array of whatever matches the wildcard. And "${SEARCH[@]}" expands into all the elements in the array ([@]), with each individually quoted.
Belatedly, I realise find itself should be capable of this. Something like:
find . -path 'D*/my folder/more/'
muru
  • 207,228
It's a little dated now but, if that can help anybody with this question, using RE's collating symbol [[.space.]] without quoting $SEARCH variable within find command line arguments, is working as long as there's no special characters into the expanded path-names in place of the asterisk.
set -x
mkdir -p te{flon,nnis,rrine}/my\ files/more
SEARCH=te*/my[[.space.]]files/more
find $SEARCH
give the following results:
+ mkdir -p 'teflon/my files/more' 'tennis/my files/more' 'terrine/my files/more'
+ SEARCH='te*/my[[.space.]]files/more'
+ find 'teflon/my files/more' 'tennis/my files/more' 'terrine/my files/more'
To prevent globing unwanted chars, One can replace the asterisk (*) by any collating elements (characters):
set -x
mkdir -p -- te{,-,_}{flon,nnis,rrine}/my\ files/more
SEARCH=te[[:alnum:][.space.][.hyphen.][.underscore.]]*/my[[.space.]]files/more
find $SEARCH
giving the following results:
+ mkdir -p -- 'teflon/my files/more' 'tennis/my files/more' 'terrine/my files/more' \
'te-flon/my files/more' 'te-nnis/my files/more' 'te-rrine/my files/more' \
'te_flon/my files/more' 'te_nnis/my files/more' 'te_rrine/my files/more'
+ SEARCH='te[[:alnum:][.space.][.hyphen.][.underscore.]]*/my[[.space.]]files/more'
+ find 'te-flon/my files/more' 'te_flon/my files/more' 'teflon/my files/more' \
'te-nnis/my files/more' 'te_nnis/my files/more' 'tennis/my files/more' \
'te-rrine/my files/more' 'te_rrine/my files/more' 'terrine/my files/more'
Note that to shorten the line, [.hyphen.] can be replaced by either [.-.] or - and [.underscore.] can be replaced by either [._.] or _.
Truncating lines with backslashes (\) added by myself for readability purpose.
daneros
I have finally found out the answer.
Add a backslash to all spaces:
SEARCH=${SEARCH// /\\ }
At this point, SEARCH contains te*/my\ files/more.
Then, use eval.
eval find ${SEARCH} -print
It's that simple! Using eval bypasses the interpretation that ${SEARCH} is from a variable.
Paddy Landau
  • 4,658
