102
I want to zip many folders in a directory tree like so
V-
 something.txt
 folder
 folder
 h.jar
When I try to zip it, it ends creating a zip archive with the v folder instead of the contents of it (the sub directories and files)
How can I avoid this?
Zanna
  • 72,312
Dami
  • 1,171
7 Answers7
86
Hope this helps.
(cd directory && zip -r ../out.zip .)
It keeps the main shell in the same directory and only changing the directory of the sub-shell which dies after the command.
YesYouKen
  • 977
68
Use the -j or --junk-paths option in your zip command.
From the zip man page:
-j
--junk-paths
Store just the name of a saved file (junk the path), and do not store directory names. By default, zip will store the full path (relative to the current directory).
Zanna
  • 72,312
robrtsql
  • 853
42
So if I understand correctly, you are trying to archive the files & folders in a particular folder but without including the root folder.
Example:
/test/test.txt
/test/test2.txt
where test.txt and test2.txt would be stored in the zip, but not /test/
You could cd into the /test/ directory then run something like,
zip -r filename.zip ./*
Which would create an archive in the same folder named filename.zip. Or if running it from outside the folder you could run,
zip -r test.zip test/*
The /* is the part that includes only the contents of the folder, instead of the entire folder.
Edit: OP wanted multiple zips, solution ended up being a bit of a hack, I am curious as to whether there is a better way of doing this.
for d in */ ; do base=$(basename "$d") ; cd $base ; zip -r $base * ; mv "${base}.zip" .. ; cd .. ; done;
jspaetzel
  • 588
32
How about this command?
$ cd somedir ; zip -r ../zipped.zip . * ; cd ..
Alfred
  • 429
(cd MyDirectory && zip -r - .) >MyArchive.zip
This lets you specify the resulting filename relative to the current directory, rather than relative to the target directory.
As a bonus, this overwrites the archive instead of adding new files to it, which was desired in my case.
Instead of . you can specify files/directories relative to the target directory that you want to include.
Unlike -j it preserves paths relative to the target directory, rather than flattening all files into a single directory.
cd `dirname path/to/archive` && zip -rq $OLDPWD/arhive.zip . && cd -
This works not only with flatten tree (like -j) and you can specify any dir (not only children)
Glech
  • 171
The other answers did not satisfy me, because they either included the whole directory structure in the zip, or included an ugly ../../../../file.zip path in the zip command.
The approach below uses a common piece of boilerplate code to get the current directory (the directory in which this script is located) as an absolute path.
#!/bin/bash
dir=$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)
(cd "path/to/some/deep/directory/" && zip -r "${dir}/file.zip" ./*)
zx485
  • 2,865
