I'm using ubuntu (3.13.0-34). I installed it, left 300M for boot, but seems that it was not enough anymore. I follow some instructions here and removed all older kernels from it.
/dev/sda6       277M  212M   52M  81% /boot
/dev/sda9       625G   71G  522G  12% /home
/dev/sda1       496M   28M  469M   6% /boot/efi
cvgaviao@ubuntu-dell:/boot$ ls -l
total 35310
-rw-r--r-- 1 root root  1162712 Ago 13 13:45 abi-3.13.0-34-generic
-rw-r--r-- 1 root root   165611 Ago 13 13:45 config-3.13.0-34-generic
drwxr-xr-x 4 root root     4096 Dez 31  1969 efi
drwxr-xr-x 5 root root     1024 Set  5 11:03 grub
-rw-r--r-- 1 root root 19145757 Set  4 00:16 initrd.img-3.13.0-34-generic
drwx------ 2 root root    12288 Fev 22  2014 lost+found
-rw-r--r-- 1 root root   176500 Mar 12 09:31 memtest86+.bin
-rw-r--r-- 1 root root   178176 Mar 12 09:31 memtest86+.elf
-rw-r--r-- 1 root root   178680 Mar 12 09:31 memtest86+_multiboot.bin
-rw------- 1 root root  3381262 Ago 13 13:45 System.map-3.13.0-34-generic
-rw------- 1 root root  5797728 Ago 13 13:45 vmlinuz-3.13.0-34-generic
-rw------- 1 root root  5799640 Ago 15 15:36 vmlinuz-3.13.0-34-generic.efi.signed
But Software Updater show me this message:
The upgrade needs a total of 73,0 M free space on disk '/boot'.
Please free at least an additional 19,2 M of disk space on '/boot'.
Empty your trash and remove temporary packages of former installations using 'sudo apt-get clean'.
The strange fact is that it wants to install kernel 3.13.0 (Ubuntu Base)
Is there any file that I could safely remove in order to let software updater to get more space?
thanks
mikewhatever
  • 33,013
Cristiano
  • 217
Like @mikewhatever suggested, boot into a live session from CD or USB stick (https://help.ubuntu.com/community/LiveCD) with an up to date Ubuntu iso image and use gparted to enlarge the partition which is mounted under /boot, i.e. /dev/sda6 (give some space from /dev/sda9). The size of the /boot partition has been badly chosen!
BACKUP ALL DATA ON PARTITIONS YOU'RE RESIZING, better the whole disk!
