I am facing a confusing problem. while using my home Wifi on ubuntu 14.04 amd64, my internet connection suddenly gives no response but in notification area it is shown as connected.
I switched my wifi on and off, it connects to my device but still no response.
My gateway is 192.168.1.1, my mask is 255.255.255.0, my IP is 192.168.1.38 but when i ping the gateway no result comes back.
I restarted couple of times, same problem.
Then I restarted and boot into my fedora 20 x86_64, same problem.
Then I restarted and boot into Windows, no problem there. everything works.
Then I restarted and boot into ubuntu again, the problem is fixed!!!!
This has happend to me so many times at home.
Can anyone tell me what is going on? What extra information i should search about?
Edit: I started downloading something and it happened again.
here is my ifconfig -a:
eth0 Link encap:Ethernet HWaddr c8:0a:a9:bf:f6:34
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:563 errors:0 dropped:0 overruns:0 frame:0
TX packets:563 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:49860 (49.8 KB) TX bytes:49860 (49.8 KB)
wlan0 Link encap:Ethernet HWaddr c4:17:fe:fb:b9:7a
inet addr:192.168.1.38 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c617:feff:fefb:b97a/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:8200 errors:0 dropped:0 overruns:0 frame:0
TX packets:7495 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9052410 (9.0 MB) TX bytes:920101 (920.1 KB)
and here is my route -n:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0
192.168.1.0 0.0.0.0 255.255.255.0 U 9 0 0 wlan0
I also checked these commands after and before mysterious disconnection, i think results are the same.
Edit: I also stopped ufw and iptables services and then,
here is my iptables -L -n -v
Chain INPUT (policy ACCEPT 2 packets, 352 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 21 packets, 1764 bytes)
and here is my arp -a
? (192.168.1.1) at ec:43:f6:fb:76:64 [ether] on wlan0
Edit: here is my lspci -vvnn | grep -i wireless -A 10:
09:00.0 Network controller [0280]: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01)
Subsystem: Lenovo Device [17aa:30a1]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 18
Region 0: Memory at f0100000 (64-bit, non-prefetchable) [size=64K]
Capabilities: <access denied>
Kernel driver in use: ath9k
