-2
I'd prefer to edit TestFile in place to get the desired output. How could I do this? This is a work box so I'd prefer to not have to install additional packages.
TestFile:
randomcollege-nt\jsmith90
randomcollege-nt\aakhbar91
randomcollege-nt\pmanning92
randomcollege-nt\dvader93
jshephard94
bwayne95
Desired output:
jsmith90
aakhbar91
pmanning92
dvader93
jshephard94
bwayne95
Roboman1723
  • 2,975
  • 26
  • 32
You can use sed:
sed -i~ 's/.*\\//' TestFile
  • -i~ tells sed to create a backup with the ~ extension.
  • s/// is substitution.
  • .*\\ means anything (.*) followed by a backslash
  • the replacement part is empty //, i.e. everything up to a backslash will be replaced by nothing.
choroba
  • 10,313
You can get output simply by using command cut:
cut -d '\' -f 2 < TestFile
Where -d is used to determine delimiter which is / here and -f for selecting fields which is 2 here.
Example:
$ cat TestFile
jshephard94
bwayne95
$ cut -d '\' -f 2 < TestFile
jsmith90
aakhbar91
pmanning92
dvader93
jshephard94
bwayne95
If you want to save output to another file then use:
cut -d '\' -f 2 < TestFile > Output
If you want to overwrite TestFile then use following command:
cut -d '\' -f 2 < TestFile|tee TestFile
Pandya
  • 37,289
Though two correct answers have been given but I am giving my personal solution--
sed 's/randomcollege-nt\\//g' testfile
Thank you,
This is another solution using awk:
 awk -F "\" '{print $(NF)}' testfile > outFile
where -F define the input field separator, than print $(NF) print out the last field.
outFile will contains:
jsmith90
aakhbar91
pmanning92
dvader93
jshephard94
bwayne95
Lety
  • 6,089
  • 32
  • 38
