I want to run pkill like below.
sudo pkill -u 11002
I cannot give sudo password multiple times, so I want to run pkill without sudo user. For this i copied pkill to home as named bkill, and then i have run the following command.
sudo setcap "cap_kill+epi" /home/rajesh/bkill
This will give kill capabilities to this binary. But whenever i run i am getting following message.
 /home/rajesh/bkill  -u 11002
result: 31270
I check running processes of that user using below command.
ps -u 11002
PID TTY          TIME CMD
340 pts/26   00:00:00 ncserver
This is showing process pid 340 is still running. I assumed cap_kill is not working.
So I tried a different approach. I have given sudo access using below commands.
sudo chown root /home/rajesh/bkill
sudo chmod u+s /home/rajesh/bkill
Even this way also not working.
Can anybody help me to resolve this??
Why don't you just give yourself permission to run pkill without a password:
sudo visudo
add
rajesh ALL = NOPASSWD: /usr/bin/pkill
You'll still need to sudo pkill, but you won't have to type a password.
glenn jackman
  • 18,218
