Trying to configure "On-access scanner using preload LIBC library" in ESET File Security.
The manual states:
... to have the On-access scanner to monitor all file system access events immediately after starting the Samba server. Within the Samba daemon initialization script (/etc/init.d/smb), we would replace the statement
daemon /usr/sbin/smbd $SMBDOPTIONS
with the following line:
LD_PRELOAD=@LIBDIR@/libesets_pac.so daemon /usr/sbin/smbd $SMBDOPTIONS
But I do not have a file /etc/init.d/smb, but there is /etc/init.d/smbd.
Can anyone tell me where to inscribe this line that would LIBC library was launched before the start of samba?
Oli
  • 299,380
So in the depths of /etc/init.d/smbd you'll find the following line which is what is actually launching smbd:
if ! start-stop-daemon --start --quiet --oknodo --exec /usr/sbin/smbd -- -D; then
The popular idea for passing through an environment variable is with env so you'd end up with:
if ! start-stop-daemon --start --quiet --oknodo --exec /usr/bin/env LD_PRELOAD=@LIBDIR@/libesets_pac.so /usr/sbin/smbd -- -D; then
Note that I expect they want you to replace @LIBDIR@ with the correct path to libesets_pac.so.
An alternative is creating a new launcher for smbd as /usr/local/sbin/smbd:
#!/bin/sh
And then just alter /etc/init.d/smbd to call /usr/local/sbin/smbd.
Oli
  • 299,380
