20
When I try to mount a cifs share with option iocharset=utf8 I receive the error: mount error 79 = Can not access a needed shared library. What shared library am I missing?
Uggla
  • 303
Probably, your Kernel doesn't contain the nls_utf8.ko module.
If it's your case, you will see similar entries in your dmesg output:
[  612.598233]  CIFS VFS: CIFS mount error: iocharset utf8 not found
[  612.598547]  CIFS VFS: cifs_mount failed w/return code = -79
To confirm it, you can try to find the nls_utf8.ko module:
ls /lib/modules/$(uname -r)/kernel/fs/nls/nls_utf8.ko
To fix, install a kernel witch contains this module, like linux-generic or linux-image-extra-virtual.
In my case (Ubuntu 14.04), the solution was:
apt install linux-generic
reboot
In newer Ubuntu versions, maybe you will need one of the linux-modules-extra kernel packages (tks @pxlinux). For example, if your current kernel is linux-generic:
apt install linux-modules-extra-$(uname -r)-generic
reboot
More info can be found at this answer at superuser and at this bug report at Launchpad.
15
When dmesg complains like this:
Let me slightly update the information for Ubuntu 16.04
When the package below is not installed only NLS for ISO_8859-1 is present
after installation of the extra kernel modules by
sudo apt install linux-modules-extra-$(uname -r)
also the UTF-8 is there.
Thanks for the hint above!
Grant
  • 103
pxlinux
  • 191
