I am trying to install nodejs but it is repeatedly failing. Attached is the log
$ sudo apt-get install nodejs
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libc-ares2 libv8-3.14.5
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
rlwrap
The following NEW packages will be installed:
rlwrap
The following packages will be upgraded:
nodejs
1 upgraded, 1 newly installed, 0 to remove and 11 not upgraded.
Need to get 0 B/4,391 kB of archives.
After this operation, 14.9 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package rlwrap.
(Reading database ... 263979 files and directories currently installed.)
Preparing to unpack .../rlwrap_0.37-5_amd64.deb ...
Unpacking rlwrap (0.37-5) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_0.10.31-1chl1~trusty1_amd64.deb ...
Unpacking nodejs (0.10.31-1chl1~trusty1) over (0.10.25~dfsg2-2ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nodejs_0.10.31-1chl1~trusty1_amd64.deb (--unpack):
trying to overwrite '/usr/share/man/man1/node.1.gz', which is also in package nodejs-legacy 0.10.25~dfsg2-2ubuntu1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for man-db (2.6.7.1-1) ...
