18
I'm using Ubuntu 14.04 with gnome classic.
I want to add 4 workspaces. I right click into the workspaces (left-bottom) and go to preferences. I change the number of workspaces from 1 to 4 and close the window. No workspaces are added and when I press to preferences again, I see a 1 not a 4.
Mateu
  • 283
Do you mean gnome-session-flashback instead of gnome classic ? If yes, you can do that by installing the compizconfig settings manager and plugins packages, i.e.
sudo apt-get install compizconfig-settings-manager compiz-plugins
You need to start the compizconfig settings manager found under
Appications -> System Tools -> Preferences
Once loaded, click on General Options and the Desktop Size tab to set the workspaces.
Harris
  • 2,588
12
Install CompizConfig Settings Manager:
After installing CompizConfig Settings Manager it should be:
Appications -> System Tools -> Preferences -> CompizConfig Settings Manager
A window will appear, accompanied by a Warning dialog. Click OK on the warning dialog.
Double-click General options on the other window.
Now click on Desktop Size. The default value is 1 (horizontal) x 1 (vertical). Change to whatever you would like to have. I chose 2 x 2 which was what I wanted, and it worked perfectly!
RoraΖ
  • 103
Venky
  • 121
