First of all, this is not a question about history, which stores all the entered commands.
I have on my workstation at work several open Terminals from which I launch simulations, examine the output and where occasionally error messages are displayed.
In Gnome Terminal there is a setting controlling the length of the scroll back, in my case the setting is set to be just shy of 10000 lines.
Now my question: How can I search the scroll-back?
In my case I want to check whether a recent error message occurred previously. Yes, I can scroll back and use my eyeballs to search for the error message in question. But for several Terminals which are potentially up to 10000 lines long, that means a serious time spent scrolling.
I assume the information in the scroll-back needs to be stored somewhere, and if is stored somewhere it might actually be searchable.
[Edit: corrected the question to be about Gnome Terminal.]
Dohn Joe
  • 323
  • 14
If the output produced by your scripts is very important to you (to look for error, warning, actions that were run and so on), then you shouldn't rely on the display of the console you're using.
You have to redirect the output of your scripts to some files, this has advantages :
  • you are no more bounded to the number of lines in the scroll buffer of the console you are using
  • you can archive the result for as long as you want to be able to retrieve what was done, even some days/weeks/months after you effectively run the script
  • you can have the errors logged to a dedicated file, different from the informational messages, making it more easy to find errors. (if the commands used in your scripts send error to STDERR and information to STDOUT).
  • you can even log to a file while still displaying output on the terminal is you use the command tee.
So, you can do this :
./script.sh | tee -a output
to copy all the output of script.sh to a file called output, appending the text to the end of the file and displaying the text on the terminal too.
Benoit
  • 7,637
The scrollback buffer is a function of your terminal or console.
If you are using the framebuffer console, it's possible to use the fbcon=scrollback: parameter at boot time to increase the size of the scrollback.
For the xfce4-terminal, go to "Edit->Settings->General->Scrollback" and change the scroll-buffer to your likings.
for kde's konsole, go to "Settings->Configure current Profile...->Scrolling->Fixed number of lines"
the classical xterm can be configured with a startup-flag -sl 777 (for 777 lines of scroll-back buffer) or via the saveLines config.
For GNU screen, start it with screen -h .
I'd go with screen, in which you can search the scrollback buffer:
/ Vi-like search forward
? Vi-like search backward
C-a s Emacs style incremental search forward
C-r Emacs style reverse i-search
In scrollback mode (or copy mode, it is the same) you can also copy and paste text.
Jan
  • 12,931
  • 34
  • 39
