A little late to the party but, I wrote a python program to reopen all my applications on reboot. This includes gedit and the last five opened files in their own tabs.
Here's the snippet from the program:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
REQUIRES:
sudo apt install xdotool
from future import print_function # Must be first import
import os
import time
OTHERS_TIME = 3 # Firefox, etc. to load up
SERVER_TIME = 1.5 # gnome-terminal-server time
BASHRC_TIME = 1.5 # Seconds to load ~/.bashrc
WINDOW_TIME = .5 # Seconds fpr window to appear
def launch_command(ext_name):
''' Launch external command in background and return PID to parent.
Use for programs requiring more than .2 seconds to run.
all_pids = get_pids(ext_name) # Snapshot current PID list
all_wins = get_wins(all_pids) # Snapshot of windows open
new_pids = all_pids
new_wins = all_wins
sleep_count = 0 # Counter to prevent infinite loops
os.popen(ext_name) # Run command in background
while new_pids == all_pids: # Loop until new PID is assigned
new_pids = get_pids(ext_name) # Snapshot current PID list
if sleep_count > 0: # Don't sleep first time through loop
time.sleep(.005) # sleep 5 milliseconds
sleep_count += 1
if sleep_count == 1000: # 10 second time-out
print('launch_ext_command() ERROR: max sleep count reached')
print('External command name:',ext_name)
return 0, 0
pid_list = list(set(new_pids) - set(all_pids))
if not len(pid_list) == 1:
print('launch_command() ERROR: A new PID could not be found')
return 0, 0
time.sleep(WINDOW_TIME) # Give time for window to appear
new_wins = get_wins(all_pids) # Snapshot of windows open
win_list = list(set(new_wins) - set(all_wins))
if not len(win_list) == 1:
#print('launch_command() ERROR: New Window ID could not be found')
#suppress error message because we aren't using window ID at all
return int(pid_list[0]), 0
# Return PID of program we just launched in background
return int(pid_list[0]), int(win_list[0])
def get_pids(ext_name):
''' Return list of PIDs for program name and arguments
Whitespace output is compressed to single space
all_lines = []
# Just grep up to first space in command line. It was failing on !
prog_name = ext_name.split(' ',1)[0]
all_lines = os.popen("ps aux | grep -v grep | grep " +
"'" + prog_name + "'").read().strip().splitlines
PID = []
for l in all_lines():
l = ' '.join(l.split()) # Compress whitespace into single space
PID.append(int(l.split(' ', 2)[1]))
return PID
def get_wins(all_pids):
''' Return list of all windows open under PID list
Currently unnecessary because we work on active window '''
windows = []
for pid in all_pids:
all_lines = os.popen('xdotool search --pid ' + str(pid)).
windows.append(int(l))
return windows
def gedit():
last_modified_files = gedit_recent_files()
command = 'gedit '
for f in last_modified_files:
# Add each file name to parameter list passed to `gedit`
command += '"' + f + '" '
# Open gedit with last five modfied files. '&' = run in background
command=command+' &'
active_pid, active_win = launch_command(command)
if active_pid == 0:
print("ERROR launching", command, \
"Aborting 'alienstart' script")
exit()
def gedit_recent_files():
''' Get list of gedit 5 most recent files:
grep --no-group-separator -B5 'group>gedit' ~/.local/share/recently-used.xbel | sed -n 1~6p | sed 's# <bookmark href="file:///#/#g' | sed 's/"//g'
/home/rick/python/mmm added=2020-05-02T15:34:55Z modified=2020-11-19T00:43:45Z visited=2020-05-02T15:34:56Z>
/home/rick/python/mserve added=2020-07-26T16:36:09Z modified=2020-11-28T01:57:19Z visited=2020-07-26T16:36:09Z>
command = "grep --no-group-separator -B5 'group>gedit' " + \
"~/.local/share/recently-used.xbel | " + \
"sed -n 1~6p | sed 's# <bookmark href=" + '"' + \
"file:///#/#g' | " + "sed 's/" + '"' + "//g'"
recent_files = []
times = []
all_lines = os.popen(command).read().strip().splitlines
uniquifier = 1 # gedit can give all open files same time
fname = l.split(' added=', 1)[0]
trailing = l.split(' added=', 1)[1]
modified = trailing.split(' modified=', 1)[1]
modified = modified.split('Z', 1)[0]
# TODO: 2038
d = time.strptime(modified, '%Y-%m-%dT%H:%M:%S')
epoch = time.mktime(d)
epoch = int(epoch)
recent_files.append(fname)
try:
times.index(epoch)
# gedit has given multiple files the same modification time
epoch += uniquifier
uniquifier += 1
except:
pass # Not a duplicate time
times.append(epoch)
N=5
top_files = []
if N > len(times):
# Less than 5 most recent files in list
N = len(times)
if N == 0:
# No most recent files in list
return top_files # return empty list
# Store list in tmp to retrieve index
tmp=list(times)
# Sort list so that largest elements are on the far right
times.sort()
#print ('5 most recent from lists and indices')
for i in range(1, N+1):
top_files.append(recent_files[tmp.index(times[-i])])
return top_files
if name == "main":
gedit()
The larger REAL program is more complicated because it opens gnome-terminal, changes directory, renames tabs and move windows to one of three monitors. Sometimes the larger program launches programs in the background, sometimes in the foreground. It polls to ensure one program is running (or finished running) before proceeding to the next program.
