I'd like to run dpkg --configure virtualbox-guest-x11 from within a shell script so it can answer N to the following question.
$ dpkg --configure virtualbox-guest-x11
Setting up virtualbox-guest-x11 (4.1.12-dfsg-2ubuntu0.6) ...
Configuration file `/etc/X11/Xsession.d/98vboxadd-xclient'
 ==> File on system created by you or by a script.
 ==> File also in package provided by package maintainer.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** 98vboxadd-xclient (Y/I/N/O/D/Z) [default=N] ?
Is there way I can pass an argument to dpkg --configure or is there a certain file where I can set the default arguments that should be accepted when the package virtualbox-guest-x11 is configured?
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
user784637
  • 11,465
Yes:
yes N | dpkg --configure virtualbox-guest-x11
or:
echo N | dpkg --configure virtualbox-guest-x11
or:
dpkg --configure virtualbox-guest-x11 <<< "N"
or, because N is the default option in this case:
dpkg --configure --force-confdef virtualbox-guest-x11
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
