On my Ubuntu 11.04 server when I try to run
 service powernap stop
as a cron job with the root user, it fails and gives me this message in syslog
 NAS CRON[10853]: (CRON) error (grandchild #10854 failed with exit status 2)
and this is emailed to the root users email account
 exec: 129: stop: not found
I can start and stop the powernap service from the command line so why doesn't it work from cron?
enzotib
  • 96,093
Looks like /sbin is not in $PATH when starting it from cron. Add a line like
PATH = /sbin:$PATH
to the crontab file.
Hmmm...it's strange that cron is trying to run "stop"...
Try making cron run this instead:
sh -c '/usr/sbin/service powernap stop'
I've had exactly this issue, and it would appear that the $PATH variable is completely empty when crontab is run, so it's not enough to put PATH=/usr/sbin;$PATH at the top of the crontab list.
So, what I did was (since I'm running this crontab as root, so I can turn off the squid proxy):
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin
and it seems to have worked.
N.N.
  • 18,589
james
