I'd like to lock the screen when I move my mouse to the bottom-right corner.
Is there a compiz-configuration for that task?
I could not find anything in the compizconfig-settings-manager and system settings.
Edward
  • 341
The simple tools to get mouse position is xdotool just install first and follow steps:
sudo apt-get install xdotool
then we are useing xdotool getmouselocation --shell to see the current position of mouse: the result will be something like this:
X=845
Y=447
SCREEN=0
or by running eval $(xdotool getmouselocation --shell) will put the position into shell variables X, Y and SCREEN. After that, we can access these variables with this:
echo $X $Y $SCREEN
Well now we need a while loop to check mouse position on every time:
while true
  do
    [get mouse position]
    [if position =bottom-right corner then lock screen]
  done
ok so our scripts would be like this:
#! /bin/sh
while true
  do
    if [ $X -ge 1919 -a  $Y -ge 1079 ]; then
        gnome-screensaver-command -l
    fi
  done
save script named "lock.sh" in your home directory and run it by sh lock.sh and move your mouse to the bottom-right corner and see the result. cool!
explain:
We combine conditions by using certain operators. For the single-bracket syntax that we’ve been using so far, “-a” used for and. and “-o” for or. Example:
if [ $foo -ge 3 -a $bar -ge 10 ]; then
The above condition will return true if $foo contains an integer g reater than or e qual to 3 (-ge 3) and also $bar contains an integer g reater than or e qual to 10. then run lock screen command line gnome-screensaver-command -l
αғsнιη
  • 36,350
I could not find any settings in the Compiz manager, nor in the Unity Tweak settings (which uses the same), but if you add the script below to your Startup Applications, it will check your screen resolution and your mouse position. If the mouse is within a marge from the corner (set in the head of the script) it will lock the screen.
How to use
  1. Install xdotool:
  2. Paste the script below in an empty file, set the marge (pixels) within which you would like the hotcorner to act, save it as screenlock.py, make it executable for convenience reasons and add it to your startup applications (Dash > Startup Applications > Add). Add add the command:
    /path/to/screenlock.py
The script:
#!/usr/bin/env python3
import time
import subprocess
marge = 3 # (pixels) increase to increase sensitivity
output = subprocess.check_output(["xrandr"]).decode('utf-8').strip().split()
idf = output.index("current")
res = (int(output[idf+1]), int(output[idf+3].replace(",", "")))
command = "gnome-screensaver-command -l"
while True:
    get_pos = subprocess.check_output(["xdotool", "getmouselocation", "--shell"]).decode('utf-8').strip().split("\n")
    pos = (int(get_pos[0][2:]), int(get_pos[1][2:]))
    if res[0] - pos[0] < marge and res[1] - pos[1] < marge:
        subprocess.Popen(["/bin/bash", "-c", command])
    time.sleep(1)
Jacob Vlijm
  • 85,475
