I am now using ubuntu 12.04. I have problem with login. It wait me for log time even though I have enter right password.And nothing happen after waiting. I try to login from guest account but same problem occur with guest account.
enter via recovery mode and make sure your computer is up to date, do the following commands to upgrade the software. This could resolve the issue because this sounds like a bug to me.
sudo apt-get update && sudo apt-get dist-upgrade
dist-upgrade install new kernels it doesn't upgrade the system to a new release of Ubuntu.
If this doesn't work, then I would upgrade to 14.04, because I think this is a bug and newer software most likely wont have this issue.
I would start by downloading Ubuntu 14.04 and put it on a USB(live-usb) and boot from it. You can upgrade your current installation from there and you don't have to make a fresh install. This involves less risk than by upgrading via do-release-upgrade form the terminal because you already have all the necessary files on your USB.
But I would also make a backup of all your files first, or those you can't lose.
Here are some alternatives on how to backup your files, there are others but these are the ones I would try.
  • live-usb
    Boot the USB -> try Ubuntu -> mount the partition -> backup the files.
  • graphical via the network
    via the network when the computer is running, network -> your computer -> log in with user/password if you have installed and configured this (your home folder needs to be shared with the network for this to work).
  • SSH
    copy the files via ssh to another device/computer
Good luck!
Alvar
  • 17,038
