Running sudo apt-get -f install said that The link /vmlinuz.old is a damaged link and:
you may need to re-run your boot loader[grub]
Here's the full output:
user@chrubuntu:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
linux-headers-3.13.0-32 linux-headers-3.13.0-32-generic
linux-image-3.13.0-32-generic linux-image-extra-3.13.0-32-generic
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
user@chrubuntu:~$ sudo apt-get autoremove
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
After this operation, 270 MB disk space will be freed.
Do you want to continue? [Y/n] y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en
en",
LC_ALL = (unset),
LC_TIME = "en",
LC_MONETARY = "en",
LC_ADDRESS = "en",
LC_TELEPHONE = "en",
LC_NAME = "en",
LC_MEASUREMENT = "en",
LC_IDENTIFICATION = "en",
LC_NUMERIC = "en",
LC_PAPER = "en",
LANG = (unset)
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_ALL to default locale: No such file or directory
(Reading database ... 232120 files and directories currently installed.)
Removing linux-headers-3.13.0-32-generic (3.13.0-32.57) ...
Removing linux-headers-3.13.0-32 (3.13.0-32.57) ...
Removing linux-image-extra-3.13.0-32-generic (3.13.0-32.57) ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-32-generic /boot/vmlinuz-3.13.0-32-generic
update-initramfs: Deleting /boot/initrd.img-3.13.0-32-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-32-generic /boot/vmlinuz-3.13.0-32-generic
The link /initrd.img.old is a damaged link
Removing symbolic link initrd.img.old
Removing linux-image-3.13.0-32-generic (3.13.0-32.57) ...
Removing symbolic link vmlinuz.old
user@chrubuntu:~$
How do I re-run the boot loader?
