Is there a way to install a deb package directly from a URL, using a shell? Something like
dpkg -i http://domain.com/path/to/package.deb
(I know I could use wget and then dpkg, I'm just wondering if there's something that does it already)
Edit: I didn't see your previous statement about knowing you could wget so this is a bit awkward... I'll leave this here for anybody who wants to know how to do this. Additionally the previous version of my answer didn't work but this version (at the expense of being somewhat longer) does:
TEMP_DEB="$(mktemp)" &&
wget -O "$TEMP_DEB" 'http://path.to/my.deb' &&
sudo dpkg -i "$TEMP_DEB"
rm -f "$TEMP_DEB"
You just need to alter the URL at the beginning. This could be aliased or written as a bash function.
I realise there are technical and security issues surrounding this (you don't get automatic updates, can the source be trusted, etc), but on a purely can-I-do-it basis, this might work.
It is not possible without creating a temporary file. Normally you would do this like
### Does not work
wget --quiet --output-document=- http://example.com/path/to/package.deb | dpkg --install -
or maybe
### Does not work
dpkg --install <(wget --quiet --output-document=- http://example.com/path/to/package.deb)
but dpkg uses mmap to access the file so neither works. There is a bug report about this: #367297
If you have (or install) Ansible:
ansible -m apt -a deb=http://domain.com/path/to/package.deb localhost
You may try with curl.
To download the file into the current folder and install from the local file:
curl -sLO https://apt.puppetlabs.com/puppetlabs-release-precise.deb && sudo dpkg -i puppetlabs-release-precise.deb
or download into /var/cache/apt/archives/ and install from there:
curl -sL -o/var/cache/apt/archives/puppetlabs-release-precise.deb https://apt.puppetlabs.com/puppetlabs-release-precise.deb && sudo dpkg -i /var/cache/apt/archives/puppetlabs-release-precise.deb
The quickest method is like this. Click to start installing shutter .
URLs used for clicking on the name:
http://packages.ubuntu.com/shutter
... and for the click on the icon:
http://apt.ubuntu.com/p/shutter
And yes you need Ubuntu Software Center to finish the installation of a .DEB. Otherwise you will have to execute the installation from Nautilus or command line.
Complete text used for this is for Ask Ubuntu only so you need to reformat this into an anchor:
[shutter](http://packages.ubuntu.com/shutter) [![Install shutter]
(https://i.sstatic.net/HjNGK.png)](http://apt.ubuntu.com/p/shutter)
More info can be found on the apturl wiki page:
1 Package:
a href="apt:package"
Bundling several packages:
a href="apt:package1,package2,package3"
Enabling repositories:
apturl apt:freevial?section=universe
So if the software is not in a default enabled repository you should add a 'section=' to it. Otherwise you can not use this method and need the user to download it and install themselves.
I actually have a script that does something similar:
Just copy and paste this script into ~/bin (create this folder if it doesn't exist):
#!/bin/bash
# ~/bin/dpkg
COUNT=0
for i in $@; do
echo $i | grep http 2>&1 > /dev/null
if [ $? == 0 ]; then
URL="$URL $i"
continue
fi
PASSTODPKG="$PASSTODPKG $i"
done
#Remove beginning and trailing space
URL=$(echo $URL | sed -e 's/^ //g' -e 's/ $//g')
if [ ! -z $URL ]; then
mkdir /tmp/debs
cd /tmp/debs
for i in $URL; do
wget "$i"
done
dpkg $PASSTODPKG /tmp/debs/*.deb
else
dpkg $PASSTODPKG
fi
Then add this to the last line in ~/.bashrc
PATH="~/bin:$PATH"
The script is just a wrapper for dpkg. The line in the ~/.bashrc file tells bash that whenever you type dpkg, it will run ~/bin/dpkg (the script), rather than /usr/bin/dpkg.
The script will just pass the arguments to dpkg if there's no URL's given. The script also supports multiple URL's. Here are some examples that will work:
sudo dpkg -i http://www.example.com/file1.deb
sudo dpkg -i http://www.example.com/file1.deb http://www.example.com/file2.deb
sudo dpkg -i http://www.example.com/file1.deb existing.deb http://www.example.com/file2.deb
sudo dpkg -i existing.deb
lynx can call dpkg (or the Software Center, if a display is available) and offer to install a downloaded package for you. For example, using:
lynx http://archive.ubuntu.com/ubuntu/pool/main/z/zsh/
And downloading one of the .deb files, the following prompt is shown:
Info for debian package '/tmp/user/1000/L11127-6774TMP.udeb':
new debian package, version 2.0.
size 2545218 bytes: control archive=5830 bytes.
857 bytes, 21 lines control
14682 bytes, 169 lines md5sums
225 bytes, 20 lines * postinst #!/bin/sh
Package: zsh-doc
Source: zsh
Version: 5.1.1-1ubuntu1
Architecture: all
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Installed-Size: 5291
Depends: zsh-common (= 5.1.1-1ubuntu1)
Section: doc
Priority: optional
Homepage: http://www.zsh.org/
Description: zsh documentation - info/HTML format
Zsh is a UNIX command interpreter (shell) usable as an
interactive login shell and as a shell script command
processor. Of the standard shells, zsh most closely resembles
ksh but includes many enhancements. Zsh has command-line editing,
built-in spelling correction, programmable command completion,
shell functions (with autoloading), a history mechanism, and a
host of other features.
This contains the documentation in GNU info and HTML formats.
Original-Maintainer: Debian Zsh Maintainers <pkg-zsh-devel@lists.alioth.debian.org>
Do you wish to:
- I)nstall the package now,
- S)ave it to a file, or
- Q)uit now
Your choice (I/S/Q)? I
Installation of Debian packages needs to be done as root.
Enter command used to become root (default=sudo):
Installing package...
[sudo] password for bro3886:
(Reading database ... 756955 files and directories currently installed.)
Preparing to unpack .../user/1000/L11127-6774TMP.udeb ...
Unpacking zsh-doc (5.1.1-1ubuntu1) over (5.0.5-4ubuntu1~ubuntu14.04.1) ...
dpkg: dependency problems prevent configuration of zsh-doc:
zsh-doc depends on zsh-common (= 5.1.1-1ubuntu1); however:
Version of zsh-common on system is 5.0.5-4ubuntu1~ubuntu14.04.1.
dpkg: error processing package zsh-doc (--install):
dependency problems - leaving unconfigured
Processing triggers for doc-base (0.10.5) ...
Processing 1 changed doc-base file...
Processing triggers for install-info (5.2.0.dfsg.1-2) ...
zsh-doc
Done. Press <return> to continue:
(Maybe I shouldn't try to install random packages off the internet.)
This one-liner based on an SO answer worked for me on Ubuntu 15.04 to identify the latest atom release on github for my environment (64-bit Ubuntu) and then install it:
sudo dpkg -i $(curl -w "%{filename_effective}" -LO $(curl -s https://api.github.com/repos/atom/atom/releases | grep browser_download_url | grep '64[.]deb' | head -n 1 | cut -d '"' -f 4))
If you do this in a tmp dir, the deb file will be cleaned up whenever you empty your tmp folder. Otherwise you can manually delete the deb package if you need the disk space.
One line solution to download, install and delete package after install:
deb=$(curl -w "%{filename_effective}" -LO https://nginx.org/packages/ubuntu/pool/nginx/n/nginx/nginx_1.20.0-1~focal_amd64.deb) && dpkg -i $deb && rm $deb && unset deb
I know that it's been a while since this question was answered/posted, but here's my humble contribution:
#!/bin/bash
dir="/tmp/dpkg-get"
url="$1"
file="${url##*/}"
if [ "$EUID" -ne 0 ]
then
echo "Please run as root"
exit
fi
[ -d $dir ] || mkdir $dir
wget -q --show-progress -O "$dir/$file" $url && \
dpkg -i "$dir/$file"
How to install dpkg-get from Pastebin with a single command:
sudo bash -c "wget http://pastebin.com/raw/GWu7qLwK -O- | tr -d '\r' > /usr/local/bin/dpkg-get && \
chmod a+x /usr/local/bin/dpkg-get"
How to use it (for example to install PowerShell 6 alpha):
sudo dpkg-get https://github.com/PowerShell/PowerShell/releases/download/v6.0.0-alpha.10/powershell_6.0.0-alpha.10-1ubuntu1.16.04.1_amd64.deb
And that's all.
I know it's not perfect, but it's simple and it works.
Remember to be careful with what you install and from where you download it.
I am just wrapped Oli's answer into a bash function that can be added to your .<shell>rc file:
function dpkg_r() {
local tmp_deb="$(mktemp)"
local src_url=$1
local args=${@:2}
wget -O $tmp_deb $src_url &&
sudo dpkg -i $tmp_deb $args &&
{ rm -f $tmp_deb; true; } || # commands above succeeded, remove tmp file
{ rm -f $tmp_deb; false; } # commands above failed, remove tmp file anyway
Name it as you want. I named it as dpkg_r where r stands for remote there
This command wait for a single URL input (three clicks to select all):
TMP_DEB="$(mktemp)" && read -p "Enter the URL of the .deb file: " FILE_URL && wget -O "$TMP_DEB" "$FILE_URL" && sudo dpkg -i "$TMP_DEB" ; rm -f "$TEMP_DEB" ; unset TMP_DEB FILE_URL
This is my version of dpkgi (dpkg-installer) script (remote and locally) based on other answers:
#!/bin/bash
# Script by Breno Maia (bremaya) <https://www.github.com/bremaya> <bremaya@gmail.com>
Check if the user is root
if [ "$(id -u)" != "0" ]; then
echo "dpkg: error: the requested operation requires superuser privileges" >&2
exit 1
fi
URL=""
PASSTODPKG=()
cleanup() {
rm -rf "$TMPDIR" # Remove the entire temporary directory
TMPDIR=$(mktemp -d) # Create a unique temporary directory
for i in "$@"; do
if [[ "$i" == http* ]]; then
URL="$URL $i"
else
PASSTODPKG+=( "$i")
fi
done
Remove spaces at the beginning and end of the URL variable
URL=$(echo "$URL" | sed -e 's/^ //' -e 's/ $//')
if [ -n "$URL" ]; then
cd "$TMPDIR"
for i in $URL; do
wget -P "$TMPDIR" "$i"
done
fi
if [ ${#PASSTODPKG[@]} -gt 0 ]; then
dpkg -i "${PASSTODPKG[@]}"
fi
cd "$TMPDIR"
dpkg -i ./*.deb
cleanup
fi
Function version:
# Add this function to your .bashrc file to install local and remote packages
dpkgi() {
return 1
fi
URL=""
PASSTODPKG=()
cleanup() {
for i in "$@"; do
URL="$URL $i"
else
PASSTODPKG+=( "$i")
fi
done
cd "$TMPDIR"
for i in $URL; do
done
fi
fi
cd "$TMPDIR"
dpkg -i ./*.deb
cleanup
fi
You can append it to /etc/bash.bashrc as it follows (it's an upgrade from Chen's script):
'dpkg-url'() {
COUNT=0
for package in "${urls[@]}"; do
if [[ $package = http ]]; then
urls+=("$package")
fi
dpkg_url="$dpkg_url "$package""
done
Remove beginning and trailing spaces
url=$(echo "$url" | sed -e 's/^ //g' -e 's/ $//g')
if [[ ! -z "$url" ]]; then
directory=$(mktemp -d);
trap 'rm -rf "$directory"' EXIT
cd "$directory" || exit
for package in "$url"; do
wget ""$package""
done
dpkg -i $dpkg_url "$directory"/*.deb
else
dpkg -i $dpkg_url
fi
Though I do not see why I get this error when calling it as it follows:
dpkg-url -i http://downloads.sourceforge.net/ldview/ldview-4.2-beta1.x64.deb
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use dselect' oraptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through less' ormore' !
