After hours upon hours of browsing to find an answer, I found something that ended up working for me. I couldn't connect to the internet at all, so I had to use a second computer and a thumb drive to accomplish this. The WiFi hardware in my machine is Broadcom BCM 4321 (14e4:4239) and the firmware disappeared when I did a clean install from 11.04 to 14.04. I was also missing the b43 and b43legacy files. It's a little bit of a work around (or so I felt) but I got it going.
For starters, you need to make sure that you have DKMS (Dynamic Kernel Module Support) so you can add to the kernel easily. You can install .deb packages using Terminal. Mateusz Stachowski on ubuntuforums.org/ pointed this out, so don't worry about that.
Inability to install external packages with Ubuntu Software Center is a bug.
You can install .deb packages from terminal with this command:
sudo dpkg -i [insert file name here}
A user by the name of Anwar, who posted on code.google.com, explained how to install DKMS without having to go through Ubuntu Software Center.
Follow the link to download the dkms package.
http://linux.dell.com/dkms/permalink/dkms_2.2.0.3-0_all.deb
Save to a convenient location.
1. Installing this through Ubuntu Software Centre didn't work; the install button would >never become available. Instead,
1) open a Terminal window
2) switch to the root context by entering the following command:
sudo bash
provide the administrator password when prompted.
3) initiate installation by entering the following command:
dpkg -i dkms_2.2.0.3-0_all.deb
Now is when I finished it up. On help.ubuntu.com, I found the article that helped me get the firmware installed.
Move The Wireless Folder To The Firmware Directory
sudo cp -r ~/wireless/* /lib/firmware/
Now let's double check to make sure the download made it to the firmware directory. To >do this type this into the terminal:
ls /lib/firmware
Ok so now that the download is in the firmware directory we need to go to that >directory. To go there open your terminal and type in:
cd /lib/firmware
Now that you have changed directories let's double check to make sure you are in the >right directory, this next code tells us where we are in the computer file directory.
This next code stands for "print working directory".
pwd
Are you at /lib/firmware if so good, if not go back one step.
Now that we are in the firmware directory. We have to extract the download, to do this >type in:
sudo -s
Then enter your password then:
tar xvf b43-all-fw.tar_.gz
Now is the firmware extracted properly? check by typing:
ls /lib/firmware/b43
or:
ls /lib/firmware/b43legacy
Do you see the ucode files? if so then delete the gz file:
sudo rm *.gz
Then:
exit
Reboot.
sudo reboot now
Originally posted ubuntuforums.org/showpost.php?p=10796508&postcount=44 by >>>>josephmills, with chili555 consulted.
You can find the b43-all-fw.tar_.gz at http://www.broadcom.com/support/802.11/linux_sta.php
