My 4 TB Seagate BUP Fast HDD won't mount on my laptop, but it works fine on my Grandma's Ubuntu computer and my friend's PC. It is recognized in Disks, but won't mount, even when I tried the solutions listed here. Disks is telling me that Partition 2 (/dev/sdc2) is "Mounted at /mnt", but I don't see it anywhere. I'm not sure what to do.
EDIT1:
Add output of blkid
sudo blkid -c /dev/null
/dev/sda1: UUID="d4dd2f23-0638-4364-a0aa-a24d0098ce46" TYPE="ext2"
/dev/sda5: UUID="NP8qMG-N13f-NSTd-t2dY-0HB2-seND-iIwyKu" TYPE="LVM2_member"
/dev/mapper/ubuntu--vg-root: UUID="1724975b-e000-44f5-a077-1b9ef5fce1e0" TYPE="ext4"
/dev/mapper/ubuntu--vg-swap_1: UUID="2882828f-b45b-4899-941f-d68a54cdfbfa" TYPE="swap"
/dev/sdb1: SEC_TYPE="msdos" UUID="3537-6261" TYPE="vfat"
EDIT2:
Added output of
sudo parted -l
Model: ATA WDC WD5000BPVT-2 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Number Start   End    Size   Type     File system   Flags
  1    1049kB  256MB  255MB  primary  ext2          boot
  2    257MB   500GB  500GB  extended
  5    257MB   500GB  500GB  logical                lvm
Model: Generic- Multi-Card (scsi)
Disk /dev/sdb: 2033MB
Sector size (logical/physical): 512B/512B
  1    127kB   2031 MB 2031 MB primary  fat16
  Error: /dev/sdd: unrecognized disk label
  Warning: Error fsyncing/closing
  /dev/sdd: Input/output error Retry/Ignore?
I have the same problem but withe an external drive. Then I recalled that this external Hard disk has been encrypted.
The only solution I know is deactivate bitlocker in a Windows 7 or 8, Pro or enterprise version (home version is not able to read encrypted hard disks).
I hope that all checks you've been doing, have not corrupted data from your hard drive.
The question may be related with this other.
victe
  • 131
