25
I installed Xfce in Ubuntu 14.04, but the network manager icon disappeared. When I run sudo nm-applet, the icon shows. Not only the network manager but also the power manager and fcitx icon disappeared. fcitx is a Chinese input method.
karel
  • 122,292
  • 133
  • 301
  • 332
Devin
  • 355
6 Answers6
24
For the benefit of further readers having the same problem I would like to note that I managed to get the indicators to show up in the xfce4 indicator area without using the indicator plugin.
screenshot showing the indicator and startup sequence
I fiddled with the settings, but I think the key point was to deactivate the gnome indicators that I marked with red in the screen shot. I reckon these are gnomish programs that might indeed need the indicator-plugin. As can be seen at the top right of the screen shot, at least the network manager and the power indicator appear. Whether there is something special for bluetooth in xfce4, I don't know.
Harald
  • 1,310
17
Make sure you have both Notification Area and Indicator Plugin on your panel.
mreq
  • 4,932
10
Test this:
Edit /etc/xdg/autostart/nm-applet.desktop:
sudo su
nano /etc/xdg/autostart/nm-applet.desktop
Go down to the Exec line.
Change the entry:
nm-applet
to
dbus-launch nm-applet
Save the file -- Control + O
Close nano -- Control + X
Reboot.
Login and you will see that the n-m icon is now back.
kyodake
  • 17,808
In my case, I needed to install network-manager, and network-manager-gnome, despite the fact that I use using xfce4.
sudo apt install network-manager
sudo apt install network-manager-gnome
sudo systemctl enable NetworkManager.service
I rebooted the system, and the network manager plugin appeared in XFCE4's tray.
Thanks for the tip with network-manager-gnome. Strangely, the xfce4-netload plugin no longer displayed anything, so WLAN could no longer be used. As described, the applet installed. Reboot. Works. MX XFCE 23 Libretto
network manager was already installed.
you can also make the network-manager applet show up with systemd, just make sure you have a notification area set
  • make a file ~/.config/systemd/user/nm-applet.service with the following content:
  • [Unit]
    Description=Network Manager Applet
    [Service] ExecStart=/usr/bin/nm-applet
    [Install] WantedBy=graphical-session.target
  • start it with systemctl --user start nm-applet
Fuseteam
  • 445
