10
Ubuntu 11.04 installed with apache2 and all the relevant packages installed. I have tried most of the blogs and made google and other forums my best friends, yet I'm unable to solve this issue.
I Need to set up a named virtual host on my local system for development.
I created the directory "vivek" in /var/www and copied the default index.html and edited some elements.
I added the file vivek.com in /etc/apache2/sites-available as follows:
# Ensure that Apache listens on port 80
Listen 80
# Listen for virtual host requests on all IP addresses
NameVirtualHost *:80
<VirtualHost *:80>
ServerName www.vivek.com
DocumentRoot /var/www/vivek
# Other directives here
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/vivek/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
</VirtualHost>
<VirtualHost *:80>
ServerAdmin webmaster@localhost
<Directory />
AllowOverride None
</Directory>
<Directory /var/www/>
AllowOverride None
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</VirtualHost>
I.e I've added these following lines
Listen 80
<VirtualHost *:80>
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
</VirtualHost>
To the default file which was already present in "sites-available" folder(took the back up of default file before editing it)
Added this in the hosts file present in /etc/hosts
127.0.0.1 localhost
127.0.1.1 vivek-PC
127.0.0.1 www.vivek.com
Performed the following operations with no errors:
root@vivek-PC:~# a2ensite vivek.com
Enabling site vivek.com.
Run '/etc/init.d/apache2 reload' to activate new configuration!
root@vivek-PC:~# /etc/init.d/apache2 reload
* Reloading web server config apache2
When I entered www.vivek.com,it gave me the default index.html in /var/www but not one present in the folder /var/www/vivek which is edited.
Later, I edited the index.html from /var/www but I was still getting the same index.html (default-before editing). All the index.htmls have been edited but Apache seems to have some hidden one which keeps coming up when I request for www.vivek.com
And the ironic thing is after I restart -- Apache came up fine but my site -- www.vivek.com failed to show up (even with the index.html which is hidden god knows where!!).. Now my browser is showing "Unable to connect "
Please help.I've been trying to set this up since a week with no successful result.
Oli
  • 299,380
mvivekc
  • 101
By reading this, I guess that you're viewing a cached file. Instead of pressing F5 or hitting the Refresh button, skip the cache on refreshing by pressing Ctrl + F5.
Alternatiely, use the command-line program curl (which is not installed by default). Example usage:
$ curl -i http://localhost/
HTTP/1.1 200 OK
Date: Sat, 02 Jul 2011 00:42:01 GMT
Server: Apache/2.2.17 (Ubuntu)
Last-Modified: Fri, 01 Jul 2011 04:12:49 GMT
ETag: "4507-b1-4a6fa3b114149"
Accept-Ranges: bytes
Content-Length: 177
Vary: Accept-Encoding
Content-Type: text/html
<html><body><h1>It works!</h1>
<p>This is the default web page for this server.</p>
<p>The web server software is running but no content has been added, yet.</p>
</body></html>
One note: I did the following on a clean apache install:
  • Add your first configuration file to /etc/apache2/sites-available/vivek.com
  • (leave /etc/apache2/sites-available/default untouched)
  • Run sudo a2ensite vivek.com
  • Run sudo /etc/init.d/apache reload
I get the same messages as you. However, the server failed to start. When stopping the server using sudo /etc/init.d/apache2 stop and starting it again using sudo /etc/init.d/apache2 start, it refused to start at all. Looking in the error log /var/log/apache2/error.log revealed some errors:
[Sat Jul 02 00:48:09 2011] [notice] Graceful restart requested, doing restart
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
[Sat Jul 02 00:48:09 2011] [warn] NameVirtualHost *:80 has no VirtualHosts
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
So port 80 seems to be in use. But if Apache is not started yet, I can confirm that nothing listens on port 80 by running sudo netstat -tpln. I reviewed the configuration and concluded that the line Listen 80 should be removed from your configuration file /etc/apache2/sites-available/vivek.com. After that, I could start the server again and using curl, I confirmed that the server is correctly responding to requests.
KISS, your second vhost block is redundant as it's covered by /etc/apache2/sites-available/default. The next configuration file is /etc/apache2/sites-available/vivek.com:
<VirtualHost *:80>
    <Directory />
        AllowOverride None
    </Directory>
        AllowOverride None
        Order allow,deny
        allow from all
    </Directory>
</VirtualHost>
Lekensteyn
  • 178,446
There is a script that makes this simple for you - https://github.com/RoverWire/virtualhost
This eventually does the same thins as explained by the answers given but does it in just one command eg. -
sudo virtualhost create mysite.local my_site
It also allows you to delete a host you created
sudo virtualhost delete mysite.local my_site
Just note that the "my_dir" assumes that it starts after /var/www
So if your site folder is in /var/www/my_site
You should run this (pass directory path without /var/www) -
You can also modify the script file & remove the default path "/var/www" so that you can pass an absolute path to the site directory
