I followed the second answer of this question to install nvidia drivers on my lenovo z570. But now, as a result, My ubuntu 14.04 is unresponsive. Mouse clicks not working. The login screen looks perfect, but after typing in the password, the screen's resolution changes to very low and nothing works...
Will i have to reinstall Ubuntu again ? or if any, what is the procedure to revert back the changes (uninstall all nvidia drivers).
Any help would be appreciated greatly.
First boot recovery mode https://wiki.ubuntu.com/RecoveryMode
Then remove the current driver
sudo apt-get remove --purge bumblebee bumblebee-nvidia primus nvidia-331
Now you can boot to your full install again, open a terminal,
Then try installing again but with two commands
sudo apt-get install bumblebee bumblebee-nvidia primus
Reboot to confirm this is not the issue
Then run
sudo apt-get install nvidia-current
Reboot
To switch between the two different GPUs first make sure this is installed and your system is upto date
sodo apt-get install linux-headers-generic && apt-get upgrade
Now install this
sudo apt-get install bbswitch-dkms
This should allow you to use the switch on your laptop to switch GPUs
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
