I installed Ubuntu 14.04 LTS 64bit on my PC. After I've installed nVidia drivers (recommended) to solve the problem of the cursor that vanishes, Ubuntu freezes randomly when I'm working, I mean that the system doesn't react to my actions except when I press Ctrl+Alt+F1 and then Ctrl+Alt+F7, with this solution everything returns to normal. I've narrowed down the cause to these 3:
  • The drivers don't work correctly
  • I was wrong to install Ubuntu on an ext4 partition
  • The swap partition is too relevant to the RAM (when I write in terminal cat /proc/sys/vm/swappiness it reports a value of 60).
I don't want to install another distro before I've tried everything possible!
Asus X53S Series, nVidia GeForce 610M 2GB dedicated, Intel Core i7 (2,20 GHz) 64bit, RAM 4GB.
Braiam
  • 69,112
Medai
  • 171
You have an nvidia Optimus (hybrid graphics) setup. You need to remove the nvidia driver and use bumblebee
sudo apt-get remove --purge nvidia-current
To install bumblebee in Ubuntu 14.04, run these commands in terminal
sudo apt-get install bumblebee bumblebee-nvidia primus nvidia-331
Now you have to install Bumblebee GUI to manage apps to be opened using nVidia. Here is the instructions:
Install Python App Indicator:
sudo apt-get install python-appindicator
Install Git:
sudo apt-get install git
Make a directory for git:
mkdir git && cd git
Check out the repository:
git clone https://github.com/Bumblebee-Project/bumblebee-ui.git
cd bumblebee-ui
sudo ./INSTALL
Go to Startup Applications and add bumblebee-indicator
Now reboot.
I did not write this here is the source for the you need optimus info
This one is the install instructions
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
