My php.ini settings are not reflected in phpinfo. It still shows upload_max_filesize as 2M but I have set it to 50M in php.ini. Can you please tell how to change php.ini properly? I'm using Ubuntu 14.04 and I made changes to file in /etc/php5/apache2/php.ini as described in Find the correct php.ini file and also restarted apache server and even restarted my laptop. Is this the right php.ini file I'm making changes to? What could be the possible reasons?
Rolen Koh
  • 743
Some time it happens that in php.ini, there is some syntax error on some line number for example
error_reporting = E_ALL && ~E_DEPRECATED && ~E_STRICT
In this case the apache does not load configuration after that line number. So this is bit complex to figure out syntax error in php.ini therefore you should try other ways to fix and you should try this solution at the end.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
You should modify post_max_size too.
According to php manual:
 post_max_size integer
    Sets max size of post data allowed. This setting also affects file upload.
    To upload large files, this value must be larger than upload_max_filesize.
    If memory limit is enabled by your configure script, memory_limit also affects
    file uploading. Generally speaking, memory_limit should be larger than
    post_max_size.
Lety
  • 6,089
  • 32
  • 38
