I just want to know after install ubuntu newly it`s need to install previous essential software again,That is really time consuming so is there any way that I write command and my essential software download and install automatically.
Asked
Active
Viewed 1.2k times
just type this
sudo apt-get install program1 program2 program3
in a terminal to install many programs in the same command. Or you can use install scripts. Which are basically .sh files that have these commands in them, example below:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install htop
Put it in a file and name it like script.sh and run it from a terminal.
Also look at this answer for more info,
you could make a script like...
#!/bin/bash
sudo apt-get update && sudo apt-get install minicom vlc
and just keep adding more packages you want installed
Klyn
- 3,381
