I installed Tomcat 7 following the Ubuntu guide. The server is working and gives me the "It works!" page on http://localhost:8080/.
Now I want to setup my own webapp using Netbeans. I generated a new Web Project with Java EE 6 and Tomcat 7. The user is on the /var/lib/tomcat7/conf/tomcat-users.xml file properly configured.
When I run the project everything seems ok, but when I open the browser it displays a 500 error.
- The Tomcat output mentions permission errors trying to access
tomcat7/logsand - The IDE logs trying to access
tomcat7/conf.
Files permissions:
lucio@lucio-pc:/$ ll /var/lib/tomcat7/logs
lrwxrwxrwx 1 root root 17 jul 24 18:07 /var/lib/tomcat7/logs -> ../../log/tomcat7/
lucio@lucio-pc:/$ ll /var/log/tomcat7/
total 136
drwxr-x--- 2 tomcat7 adm 4096 ago 28 10:50 ./
drwxrwxr-x 15 root syslog 4096 ago 28 09:29 ../
-rw-r--r-- 1 tomcat7 tomcat7 800 ago 26 17:23 catalina.2014-08-26.log.gz
-rw-r--r-- 1 tomcat7 tomcat7 5173 ago 27 21:59 catalina.2014-08-27.log
-rw-r--r-- 1 tomcat7 tomcat7 31285 ago 28 10:36 catalina.2014-08-28.log
-rw-r--r-- 1 tomcat7 root 44192 ago 28 10:36 catalina.out
-rw-r--r-- 1 tomcat7 tomcat7 45 ago 26 16:19 localhost.2014-08-26.log.gz
-rw-r--r-- 1 tomcat7 tomcat7 0 ago 27 11:15 localhost.2014-08-27.log
-rw-r--r-- 1 tomcat7 tomcat7 433 ago 28 09:49 localhost.2014-08-28.log
-rw-r--r-- 1 tomcat7 tomcat7 7435 ago 26 17:23 localhost_access_log.2014-08-26.txt
-rw-r--r-- 1 tomcat7 tomcat7 0 ago 27 11:15 localhost_access_log.2014-08-27.txt
-rw-r--r-- 1 tomcat7 tomcat7 15186 ago 28 09:58 localhost_access_log.2014-08-28.txt
I don't understand why can't access the files, you can see that the user and group tomcat7 has permissions to the files. Is there a user for the JVM that needs privileges over the files?
I also tried changing files ownerships as mentioned here but it doesn't change at all.
The /etc/default/tomcat7 file has:
TOMCAT7_USER=tomcat7
TOMCAT7_GROUP=tomcat7
So I guess it is running as tomcat7 user.
I added my user into the tomcat7 group:
sudo usermod -aG tomcat7 $USER
And then restarted the machine, but the problem persist.
