Yesterday, I had installed Ubuntu Desktop in my system which already had Windows XP. After installation, when I restart the computer only Ubuntu is getting started as the timeout is set to 10 second only. And by the time my keyboard get unable the OS Ubuntu >get start up. Hence I try to change the timeout in in /etc/default/grub. But I am unable to change as it say it is write-protected. How do I change this setting?
muru
  • 207,228
You should try using the sudo command.
The sudo command, in a nutshell, allows you to run commands as the Superuser. In other words, it allows you to do WHATEVER you want with your pc. WARNING: SUDO IS NOT A TOY.
Try opening a terminal and running the command sudo gedit /etc/default/grub. It will ask you for your password. Type it in. (Note that there will be no masking character, or any character for that matter). Then, it'll open GEdit with the ability to change that file.
You can substitute any text editor in place instead of gedit
There is also a graphical version of sudo, called gksudo. If you are more comfortable with ONLY GUI, hit Alt+F2 and type gksudo gedit /etc/default/grub.
To learn more about sudo, run man sudo in a command prompt.
Kaz Wolfe
  • 34,680
