I am getting
fatal error maximum function nesting level of '100' reached aborting..
It seems I have to edit
xdebug.max_nesting_level from 100 to more.
But I am unable to find the correct file in where I should edit this? I am using Ubuntu 14.04 , lighttpd webserver and Php..
From internet I saw I have to edit php.ini file in /etc/php5/apache2..
But I am using lighttpd.
In my /etc/php5/ there are three folders namely
  1. cgi
  2. cli
  3. mods-available
In the cgi and cli folder there are php.ini file, But those 2 files did not contain anyting to edit xdebug.
In mods-available folder I got 1 file namely xdebug.ini and it just contains
zend_extension=xdebug.so
So I need help how to edit xdebug.max_nesting_level in ubuntu 14.04 PHP and Lighttpd. Sorry for my bad English. Seeking your help to solve this
oxvoxic
  • 151
To fix the issue, I edited /etc/php5/apache2/conf.d/20-xdebug.ini and added the following line:
xdebug.max_nesting_level = 250
Jens Erat
  • 5,131
  • 33
  • 37
phpinfo show you default value for all xdebug variables, this means that xdebug.so extension is correctly loaded by php.
In order to change xdebug.max_nesting_level default settings open xdebug.ini and add:
 xdebug.max_nesting_level=150
Similarly, you can also change other xdebug variables.
Lety
  • 6,089
  • 32
  • 38
