CORRECTION 3: SOLVED! I needed to add the the official DNS server of my departement's VLAN as DNS to the clients.
I've read through a large number of posts about iptables issues when using Linux as a router, but none could help me with the following:
I am setting up a number of student workstations in our university department, where we have limited IP's in a VLAN. The workstations need to communicate with each other and go online. They explicitly should not be reachable from the internet. Instead of giving each workstation one of the rare IP's in the university VLAN i want to use the following setup:
We have a server which is running Ubuntu 14.04 server with 4 Ethernet ports (i use 2 for this setup).
1st port is em1 and is plugged into a L2-switch together with all the workstations.
2nd port is em2 and is plugged into the university VLAN.
First the problem, then my setup:
- I can reach the server via ssh over the web, i can ping 8.8.8.8, www.example.com and other 192.168.99.x clients in the LAN from it, so for that one all works fine.
- The clients can ping each other, also 8.8.8.8, but not www.example.com. That is why i am thinking i need another iptable setting for the DNS. Same in any browser, i can't resolve external websites. In the windows clients, the Network Settings show connection to the internet, in the Linux clients, things like wget and apt-get install work. I have tried manually setting the Google DNS servers 8.8.8.8 and 8.8.4.4 for the clients, but to no avail, even though they can ping them. (The solution was to use the official DNS from the VLAN)
CORRECTION: The wget/apt-get stuff seems to work only sometimes.
CORRECTION 2: I had a typo in at least one of the DNS entries for one client, i will try the rest tommorow and then mark this as closed.
Settings etc.:
I have activated forwarding in the kernel by uncommenting
net.ipv4.ip_forward=1 in /etc/sysctl.conf.
My /etc/network/interfaces entries for the 2 Ethernet ports look like this:
auto em2
iface em2 inet static
address x.x.x.x
netmask x.x.x.x
network x.x.x.x
gateway x.x.x.x
dns-nameservers x.x.x.x x.x.x.x
dns-search x.example.com
pre-up iptables-restore < /etc/network/iptables.up.rules
post-down iptables-save > /etc/network/iptables.up.rules
auto em1
iface em1 inet static
address 192.168.99.252
netmask 255.255.255.128
(The em2 parameters are redacted for privacy reasons, but i don't think they play a role here. Please note we have two internal DNS servers, this might play a role in the problem?)
I also have setup iptables with sudo iptables -t nat -A POSTROUTING -o em2 -j MASQUERADE
so sudo iptables -t nat -L gives me:
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
Chain INPUT (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- anywhere anywhere
(that second entry must have happened by accident, but shouldn't be concerning, right?)
All the clients have static IP's with the following settings:
- IP: 192.168.99.22 or similar
- Subnetmask: 255.255.255.128
- Gateway: 192.168.99.252
The Solution was to add the official DNS entry from my departement's VLAN to the clients DNS entries. The router was not configured to be used as a DNS on it's own and did not redirect DNS requests to the outside DNS. So for every client: - DNS: Official VLAN DNS of outside network
