I have the following crontab entry to automate copying of my files to separate W/S in the network. However, it does not copy the files but produce the log file. here is the file contents
#! /bin/bash
echo "Rsync - MA Inbound Files"
rsync -rvu /media/hdd2/MA-Inbound /media/miracle/
echo "Completed MA Inbound Files Sync, Starting Tally.ERP 9 Data File Sync"
rsync -rvu /media/hdd2/Tally.ERP9 /media/miracle/
echo "Completd Tally.ERP9 Data File Sync, Starting 2011 Accounts Files Sync"
rsync -rvu /media/hdd2/"2011 Accounts" /media/miracle/
echo "Completd 2011 Accounts Files Sync, Starting 2012 Accounts Files Sync"
rsync -rvu /media/hdd2/"2012 Accounts" /media/miracle/
echo "Completd 2012 Accounts Files Sync, Starting 2012 Files Sync"
rsync -rvu /media/hdd2/"2012 Files" /media/miracle/
echo "Completd 2012 Files Sync, Starting 2013 Accounts Files Sync"
rsync -rvu /media/hdd2/"2013 Accounts" /media/miracle/
echo "Completd 2013 Accounts, Starting Admin Files Sync"
rsync -rvu /media/hdd2/"Admin" /media/miracle/
echo "Completd Admin Files Sync, Starting MA_Staff Data File Sync"
rsync -rvu /media/hdd2/MA_Staff /media/miracle/
echo "Completd MA_Staff Data File Sync, Starting MA-Outbound Data File Sync"
rsync -rvu /media/hdd2/MA_Outbound /media/miracle/
echo "Completd MA-Outbound Data File Sync, Starting Staff Pic Data File Sync"
rsync -rvu /media/hdd2/"Staff Pic" /media/miracle/
echo "Completd Staff Pic Data File Sync, End OF Syn"
here is the command which I have put in the crontab file
30 22 * * * /Desktop/marsync.sh >AutoRsyncLogfile.txt
When I copy these commands individually, it works flawlessly
Hope some one can help me out wit this.....
Thank you
Jeremy Kerr
  • 27,829
Neil
  • 237
You don't state what the log file contains; I assume it's empty.
If that's the case, it looks like your problem is due to the path used in the crontab file:
The /Desktop part is probably incorrect; the Desktop directory is usually in your home directory (ie, /home/<username>), and can be referenced by the $HOME environment variable.. If you change this to something like:
30 22 * * * $HOME/Desktop/marsync.sh >AutoRsyncLogfile.txt
- then this should work. You'll also need to ensure that the marsync.sh file is executable:
chmod a+x $HOME/Desktop/marsync.sh
Also, you might want to capture standard error (in addition to standard output) to your log file. Use &> to do this:
30 22 * * * $HOME/Desktop/marsync.sh &>AutoRsyncLogfile.txt
Jeremy Kerr
  • 27,829
-1
You have to call all commands including path : /usr/bin/rsync , or specify path in the script: look here
laugeo
  • 2,880
  • 14
