My computer is a Lenovo IdeaPad U410 Touch with Ubuntu 14.04 LTS. I want to install Chrome.
When I tried to install Google Chrome I was asked what download package to choose:
32 bit deb (for Debian/Ubuntu)
64 bit deb (for Debian/Ubuntu)
32 bit rpm (for Fedora/openSUSE)
64 bit rpm (for Fedora/openSUSE)
So what should I choose?
Vivi
Alternatively, there is the Chromium-browser package, which is available in the software repository, or installed by:
sudo apt-get update && sudo apt-get install chromium-browser
The main difference between Chromium-browser and Chrome is that the former is an community maintained version of Chrome.
As a result of this (among other things) the proprietary Flash plug-in included in Chrome is not included in Chromium, altough you can enable this during intallation or afterwards by installing the pepperflash plugin. Install banshee
MJB
  • 1,874
According to the specs of your system, most likely you have Ubuntu 64bit installed, so you can install the 64bit deb file for Ubuntu.
To check which version of Ubuntu is installed on your machine, see Checking your Ubuntu Version
Or
You can install google chrome in ubuntu this way, just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command(s) below:
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
sudo sh -c 'echo "deb http://dl.google.com/linux/chrome/deb/ stable main" >> /etc/apt/sources.list.d/google-chrome.list'
sudo apt-get update
sudo apt-get install google-chrome
Mitch
  • 109,787
You should choose
Just double-click on downloaded file and follow istructions.
As @Mitch mentioned, there is Google Chrome repository, but after installation of Google Chrome from this package, you'll have repository added. No need for the terminal!
enedil
  • 1,002
Open a terminal and type:
uname -i
The output will indicate x86_64 for 64 bit Debian/Ubuntu or i386 for 32 bit Debian/Ubuntu.
First,
to download the x86_64 bit version, open a terminal and type:
wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
Then,
to install the x86_64 bit version, type:
sudo dpkg -i google-chrome-stable_current_amd64.deb
Or,
use these two commands to install the i386 or 32bit version instead:
https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb
sudo dpkg -i google-chrome-stable_current_i386.deb
mchid
  • 44,904
  • 102
  • 162
