I'm having problems installing LMMS using cmake. I downloaded the tar file, and created the build folder inside of the extracted directory, then run cmake. I've attached the error log at the bottom. I'm a beginner when it comes to Ubuntu, so I'd appreciate any help. I've tried using the Software Center, but it has an older version of LMMS.
Thanks!
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /home/joseph/anaconda/bin/clang++
Build flags:
Id flags:
The output was:
/usr/bin/ld: cannot find -lstdc++
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Determining if the CXX compiler works failed with the following output:
Change Dir: /home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp
Run Build Command:/usr/bin/make "cmTryCompileExec633473811/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec633473811.dir/build.make CMakeFiles/cmTryCompileExec633473811.dir/build
make[1]: Entering directory `/home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp'
/usr/bin/cmake -E cmake_progress_report /home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/CMakeFiles 1
Building CXX object CMakeFiles/cmTryCompileExec633473811.dir/testCXXCompiler.cxx.o
/home/joseph/anaconda/bin/clang++     -o CMakeFiles/cmTryCompileExec633473811.dir/testCXXCompiler.cxx.o -c /home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTryCompileExec633473811
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec633473811.dir/link.txt --verbose=1
/home/joseph/anaconda/bin/clang++        CMakeFiles/cmTryCompileExec633473811.dir/testCXXCompiler.cxx.o  -o cmTryCompileExec633473811 -rdynamic
make[1]: *** [cmTryCompileExec633473811] Error 1
make[1]: Leaving directory `/home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp'
make: *** [cmTryCompileExec633473811/fast] Error 2
Determining if files soundcard.h exist failed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec4188567017/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec4188567017.dir/build.make CMakeFiles/cmTryCompileExec4188567017.dir/build
Building C object CMakeFiles/cmTryCompileExec4188567017.dir/CheckIncludeFiles.c.o
/usr/bin/cc    -o CMakeFiles/cmTryCompileExec4188567017.dir/CheckIncludeFiles.c.o   -c /home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/CheckIncludeFiles.c
/home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/CheckIncludeFiles.c:2:23: fatal error: soundcard.h: No such file or directory
 #include <soundcard.h>
compilation terminated.
make[1]: *** [CMakeFiles/cmTryCompileExec4188567017.dir/CheckIncludeFiles.c.o] Error 1
make: *** [cmTryCompileExec4188567017/fast] Error 2
Source:
int main(){return 0;}
Determining if files process.h exist failed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec3312614237/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3312614237.dir/build.make CMakeFiles/cmTryCompileExec3312614237.dir/build
Building C object CMakeFiles/cmTryCompileExec3312614237.dir/CheckIncludeFiles.c.o
/usr/bin/cc    -o CMakeFiles/cmTryCompileExec3312614237.dir/CheckIncludeFiles.c.o   -c /home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/CheckIncludeFiles.c
/home/joseph/Desktop/lmms-1.0.3/build/CMakeFiles/CMakeTmp/CheckIncludeFiles.c:2:21: fatal error: process.h: No such file or directory
 #include <process.h>
make[1]: *** [CMakeFiles/cmTryCompileExec3312614237.dir/CheckIncludeFiles.c.o] Error 1
make: *** [cmTryCompileExec3312614237/fast] Error 2
Source:
You can install LMMS 1.0.3 in Ubuntu 14.04 and 14.10 without difficult compilations with ppa:israeldahl/lmms-1.0.3 repository.
sudo add-apt-repository ppa:israeldahl/lmms-1.0.3
sudo apt-get update
sudo apt-get install lmms
