I have been trying to get Wake On Lan to work on my Ubuntu server (14.04.1 LTS), which I have configured as a home NAS box. I have followed several tutorials to try to get this working, but for some reason, which I can't trace, it is not working.
The system is an old (4-5 year old) shuttle pc system (Shuttle SN78SH7), amd64 cpu (AMD Athlon 64 X2 7550).
Steps taken so far
  1. I have set WoL on my BIOS
  2. I have enabled WoL (method g) on eth0
  3. I have added a script so that eth0 stays as g on startup
  4. I can confirm that the green and orange lights on the network card are on
If I use ethtool, I can see the following, which I believe means it is configured as expected.
Supports Wake-on: g
Wake-on: g
I am using wolcmd (from a mac), to send the magic packet, to the MAC address, IP address, and subnet specified in ifconfig eth0 (to port 9).
I am not sure what the next steps should be to try to resolve the problem.
UPDATE
I can confirm that WoL does indeed work sometimes if I suspend (pm-suspend), but does not if I use (halt -p or shutdown -h now). Suspend seems to be really unstable, so using that is not likely to be a good answer for me.
guntbert
  • 13,475
Codemwnci
  • 1,259
This is not a Linux-specific issue. Wake-on-lan is implemented by the motherboard and network card, not the operating system. Try upgrading your motherboard BIOS if you can, and also note from the SN78SH7 manual:
WOL(PME#) From Soft-Off If this item sets to Enable, the system power will be turned on when the LAN port receives an incoming signal. You have to connect the fax/modem to the mainboard Wake On LAN connector for this feature to work. The choice: Enabled or Disabled.
MAC Resume from S4/S5 This item allows you to enable/disable the MAC Resume from S4/S5. The choice: Disabled or Enabled.
You need to enable both of these options. In particular, MAC Resume from S4/S5 is needed to power up a shut down PC.
bain
  • 12,200
  1. First, install ethtool:
    sudo apt install ethtool
  2. For testing and temporarily enabling WoL:
    ethtool -s eth0 wol g
    Replace eth0 with the name of your network interface.
  3. To enable WoL permanently edit /etc/network/interfaces and add the next line (from Debian 6 "Squeeze" and above):
    iface eth0 inet dhcp
         ethernet-wol g
David Foerster
  • 36,890
  • 56
  • 97
  • 151
