Please assist me. I am eager to install Ubuntu 14.01 on a different partition but I do not know how to do it. I have HP with Windows 7 pre-installed then I upgraded to Windows 8.1
Please show me how to make a dedicated partition to install Ubuntu 14.01.
Please find the partition that I have:
partition:  /dev/sda1  NTFS      label system     922.50  KB
            /dev/sda2  NTFS                       199.00 MIB    flags: boot
            /dev/sda3  NTFS      label receovery  488.77  GB
            /dev/sda4  unknown                     16     GB
            unallocated                             1    MIB
techraf
  • 3,316
Most of the time, when you start the Ubuntu installation, it will detect Windows partitions and guide you through making space for Ubuntu. If it doesn't, you have to manually partition, which isn't hard at all for someone like me, but I use Gentoo, so that's different. Anyways, if the Ubuntu installer cannot detect windows paritions, you will have to click on the options that is under "Install Ubuntu" which is called "Something Else", after you click that, you will have to make the Windows Partition smaller to make room for Ubuntu, I suggest >40GB. Then you will make a new parition, which you will have to set as ext4 or btrfs, and choose the / mount point. If you are low on RAM, leave an extra 4 - 8 GB to partition as swap.
