I get errors for all these commands when I try to use vim (though vim then works):
autocmd BufWritePre *.rb :%s/\s\+$//e
set filetype off
filetype plugin on
filetype indent on
syntax on " Turn on syntax highlighting
match ExtraWhitespace /\s\+$/
autocmd BufWinEnter * match ExtraWhitespace /\s\+$/
autocmd InsertEnter * match ExtraWhitespace /\s\+\%#\@<!$/
autocmd InsertLeave * match ExtraWhitespace /\s\+$/
autocmd BufWinLeave * call clearmatches()
let mapleader = ","
set foldmethod=indent   "fold based on indent
set foldnestmax=10      "deepest fold is 10 levels
set nofoldenable        "dont fold by default
set foldlevel=1         "what I use
let loaded_matchparen = 1 " MDD Turn off matching bracket " Ubuntu14 filetype plugin indent on    " required
If I comment these lines out in my .vimrc I don't get any errors.
But I suspect I may have now 'lost' those settings.
Is there a different form for them or something in vim in Ubuntu 13?
Errors:
Three categories:
  • Sorry, the command is not available in this version
  • Option not supported
  • Unknown option
Details:
$ vi .vimrc
Error detected while processing /home/durrantm/.vimrc:
line   20:
E319: Sorry, the command is not available in this version: autocmd BufWritePre *.rb :%s/\s\+$//e
line   24:
E519: Option not supported: filetype
line   25:
E319: Sorry, the command is not available in this version: filetype plugin on
line   26:
E319: Sorry, the command is not available in this version: filetype indent on
line   27:
E319: Sorry, the command is not available in this version: syntax on " Turn on syntax highlighting
line   37:
E319: Sorry, the command is not available in this version: match ExtraWhitespace /\s\+$/
line   38:
E319: Sorry, the command is not available in this version: autocmd BufWinEnter * match ExtraWhitespace /\s\+$/
line   39:
E319: Sorry, the command is not available in this version: autocmd InsertEnter * match ExtraWhitespace /\s\+\%#\@
line   40:
E319: Sorry, the command is not available in this version: autocmd InsertLeave * match ExtraWhitespace /\s\+$/
line   41:
E319: Sorry, the command is not available in this version: autocmd BufWinLeave * call clearmatches()
line   48:
E319: Sorry, the command is not available in this version: let mapleader = ","
line   52:
E518: Unknown option: foldmethod=indent
line   53:
E518: Unknown option: foldnestmax=10
line   54:
E518: Unknown option: nofoldenable
line   55:
E518: Unknown option: foldlevel=1
line   57:
E319: Sorry, the command is not available in this version: let loaded_matchparen = 1 " MDD Turn off matching brac
ket highlighting.
line   58:
E319: Sorry, the command is not available in this version: filetype plugin indent on
Turns out I didn't have vim, just had vi, due to dependency issues after the upgrade.
tl;dr; - needed older versions of dependencies. Fixed with:
$ sudo apt-get remove vim-common
$ sudo apt-get remove vim-runtime
$ sudo apt-get update && sudo apt-get install vim
Change .vimrc setting "set filetype off" => "filetype off"
Full Version...
Fix was:
Attempted to do:
apt-get install vim
But got message
 vim : Depends: vim-common (= 2:7.4.052-1ubuntu3) but 2:7.4.335-1~ppa1~s is to be installed
       Depends: vim-runtime (= 2:7.4.052-1ubuntu3) but 2:7.4.335-1~ppa1~s is to be installed
So then I tried:
$ sudo apt-get install vim-common
Reading package lists... Done
Building dependency tree
vim-common is already the newest version.
Finally, realizing that the messages say the dependency is 2:7.4.052 but I have 2:7.4.335 for vim-common and vim-runtime, in other words I had more recent versions. Realizing this the final fix was:
Then I was able to do;
This fixed all the issues except for one line
set filetype off
which I changed to
filetype off
