First of all I apologize for my english, but I'm stuck and I don't know much of linux.
When I try to install Dropbox in my ubuntu it get stuck and I try to close it, but know I have a serching (applying changes) on the progress tab in ubuntu software center. Since I was trying to solve this I first use the comand sudo apt-get update and I get this:
[sudo] password for mel:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
then I use this comands that I found in other fourum sudo killall -9 dpkg and update again, it works but at the end I get this:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
when I run sudo dpkg --configure -a I get this
Setting up nautilus-dropbox (0.7.1-2) ...
Dropbox is the easiest way to share and store your files online. Want to learn more? Head to http://www.dropbox.com/
Downloading Dropbox... 100%
And it get stuck again, please help
