I recently updated from Ubuntu 12.04 LTS to 14.04 LTS and for the first time it worked!
However, whenever I move my mouse over an application icon on the unity shell, the animation takes forever to show me what the name of the application is ( A.k.a the tooltip ). The same happens with menus and sub-menus.
Other than that, it is overall in general, slow. I just want to know if there are any tips to fix this or make my system faster.
This is what it says when I type in glxinfo | grep renderer:
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.4, 128 bits)
Output of lspci | grep VGA:
00:02.0 VGA compatible controller: Intel Corporation 82865G Integrated Graphics Controller (rev 02)
programking
  • 1,541
Your system is not currently using hardware acceleration for graphics - to enable this, you will need to try to update the drivers. I know of four options, only one of which has ever worked well for me.
Before you use any of these options, you may also want to run sudo apt-get install linux-firmware-nonfree - this will load the firmware for which there is no source code.
Option 1 (the only one that worked for me) Use the graphics drivers from oibaf:
sudo add-apt-repositoryppa:oibaf/graphics-drivers
sudo apt-get update
sudo apt-get upgrade
More information can be found at launchpad
Option 2 - use the xorg-edgers. These can be found on launchpad, but they are not always entirely stable and may break your system
Option 3 - download and compile the official slick new and totally advanced intel drivers from 01.org. Before you do this, read about how to uninstall them!
Option 4 - in the software sources (open the dash and type software sources), the rightmost tab 'Additional Drivers' may have drivers that can work in your system. Again, you should review how to remove them, before you install them.
Charles Green
  • 21,859
I don't have enough rep to comment, but what's the output of swapon -s? If your not running a certain amount of swap space, your not doing your memory any favours.
To make this more of an answer than a comment, I suggest also trying to remove as much of the extraneous bloatware that comes with ubuntu as possible. It's up to you to decide what you do and don't need, but go exploring. Run top -c and see which programs and services are using a lot of CPU, and if you don't need them running, kill the process. If you don't need them at all, purge them.
Another good place to look for stuff that uses resources is in the services. sudo service --status-all will give you a list of running services. I'm not going to assume that you aren't running a production server, but if you don't need apache2, sudo service apache2 stop, if you don't need mysql, cups, dictd, etc.. turn it off. It may not give you the jump your looking for, but every little bit counts.
blanket_cat
  • 1,554
