I had to reinstall the entire OS a little while ago and I have been trying to reinstall all of the programs I had before but I got a bit a of a problem now. I was trying to download dropbox from synaptic but it cannot finish the process and as a result I cannot update anything anymore. The line that comes out is:
  E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
  E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
I have tried:
sudo apt-get install -f
sudo apt-get -f install
sudo rm /var/lib/dpkg/lock
sudo apt-get -f update
sudo dpkg --clear-selections
sudo dpkg --configure -a
But nothing seems to work.
So is there a way to solve this??
Thanks
Tim
  • 33,500
This command should find, identify and kill the proses that has locked dpkg
sudo fuser -vki /var/lib/dpkg/lock; sudo dpkg --configure -a
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
You can run the following commands to remove or install an application.
sudo apt-get autoremove
apt-get remove --purge packagename
you can check this post for completely remove an application
msnfreaky
  • 179
