I had the same problem with version 15 IntelliJ after upgrading on OS Linux Ubuntu 12.04
I found that because the Android SDK wasn't in the home folder of the user running IntelliJ that you had to change the Folder/file permissions before it would see this
Mine was in the root
Issuing the command chown -R /path/to/android_sdk_dir solved the problem for me
If this fails after doing this delete the ~/.ideaC(Lastversion number) any previous ~/.ideaC(Lastversion numbers) folder's and then re open intelliJ
You will have to go through the initialization of the IDE and give the path to your Java installation ver8 upwards only on intelliJ version15 and there after your android sdk installation
I found this can also cause conflicts
As a further tip add the following to the very end of your ~/.bashrc using one of your editors (nano , vi etc )
Example vi ~/.bashrc
The following lines set the Android Path
PATH=$PATH:/path/to/android/:/path/to/android/tools
export PATH
For SDK version r_08 and higher, also add these two lines for adb:
PATH=$PATH:/path/to/android/platform-tools
export PATH
for setting android emulator to 32 bit version add this line
export ANDROID_EMULATOR_FORCE_32BIT=true
Exit your choice of editor (vi, nano, etc ) saving your bashrc file then source .bashrc with the command below
source ~/.bashrc
Hope that helps you
