For the last 3 years I've been using a Samsung notebook. I was using Ubuntu 13.10 until 2 weeks ago. Then I decided to format and install Ubuntu 14.04 LTS.
Everything was working great, until the third day, when I did not do anything else than installing the software updates, I noticed my battery was not being recognized. The battery indicator shows charging, and when I click it it just says Battery. The day started to malfunction just said unknown battery, and when I unplugged my laptop it shut down.
If a try to turn on my laptop with the battery in and not plugged into an AC adapter, it does not turn on: it only works when its plugged in. Also, when its plugged in with the battery the light showing the battery status is now always switching from green to red (which it never did before).
I guessed it was just my battery dieing, so I tried in another notebook like mine and was working perfectly, full battery, 3 hrs and a half running. How can I get Ubuntu to recognize my battery? I really don't want a laptop that is a portable PC, I need a portable laptop again.
I have the same problem for ASUS Zenbook and resolved with:
edit grub:
sudo vi /etc/default/grub
change like below:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi="
GRUB_CMDLINE_LINUX="acpi=force pcie_aspm=force drm.vblankoffdelay=1 i915.semaphores=1"
update grub:
sudo update-grub
and restart
-1
Something like this happened to me when I replaced the internal battery in my Dell XPS14 laptop with one direct from Dell, spec'd for this laptop. There was no indicator icon, and cat /proc/acpi/battery/bat0/info or whatever the path is simply reported that no battery was present. After trying a few different simple solutions suggested by google without success, I booted back up and found that cating the same file now gave useful info. I purged and reinstalled indicator-power, rebooted, and the indicator was back.
My only explanation is that, with the battery actually being new and not refurbished, it needed a few minutes of charging to gather history and start reporting statistics to the OS. I realize this probably doesn't apply to your situation, so feel free to ignore this answer, but I think this might be a useful perspective for other Googlers of "ubuntu does not recognize new battery", like myself.
