I have installed Xilinx 14.7 in ubuntu 14.04 LTS machine(i386 - 64bit). But I am unable to run lmgrd (for starting the license server).
When I googled this problem, I found that lsb-core package needs to be installed. But the package is having many dependencies, I want to know how to install lsb-core package with all the necessary dependencies. Thanks for the help
On running sudo apt-get install lsb-core I got the following output:
Package lsb-core is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'lsb-core' has no installation candidate
So I downloaded lsb-core package from http://packages.ubuntu.com/trusty/misc/lsb-core site and used sudo dpkg -i ./lsb-core_4.1+Debian11ubuntu6_i386.deb to install it
By doing it, I got the following output
Selecting previously unselected package lsb-core.
(Reading database ... 163205 files and directories currently installed.)
Preparing to unpack .../lsb-core_4.1+Debian11ubuntu6_i386.deb ...
Unpacking lsb-core (4.1+Debian11ubuntu6) ...
dpkg: dependency problems prevent configuration of lsb-core:
lsb-core depends on libc6 (>> 2.3.5).
lsb-core depends on libz1.
lsb-core depends on libncurses5.
lsb-core depends on libpam0g.
lsb-core depends on lsb-invalid-mta (>= 4.1+Debian11ubuntu6) | mail-transport-agent.
lsb-core depends on at.
lsb-core depends on binutils.
lsb-core depends on cron | cron-daemon.
lsb-core depends on libc6-dev | libc-dev.
lsb-core depends on locales.
lsb-core depends on m4.
lsb-core depends on mailx | mailutils.
lsb-core depends on ncurses-term.
lsb-core depends on pax.
lsb-core depends on psmisc.
lsb-core depends on alien (>= 8.36).
lsb-core depends on python3.
lsb-core depends on lsb-security (>= 4.1+Debian11ubuntu6).
lsb-core depends on time.
dpkg: error processing package lsb-core (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db (2.6.7.1-1) ...
lsb-core
I am unable to install gdebi. On running `sudo apt-get install gdebi`
Package gdebi is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or is
E: Package 'gdebi' has no installation candidate
I want to know how to install `lsb-core` package with all the necessary dependencies in one go.
