I am suffering from occasional desktop freezes and am still investigating the cause. (Links forthcoming.) In the meantime I came across the following suggestion to cpulimit the unity-panel-service, which is working great so far!
sudo cpulimit -eb unity-panel-service -l 30
I would now like to configure cpulimit so that it:
  • starts as soon as I log in
  • runs in the background (no terminal required)
  • if unity-panel-service restarts, it should discover and limit the new process
Is this possible?
Note: I am aware that this is a workaround to a desktop bug. My question is primarily about using cpulimit, rather than the bug/workaround. When I have a moment I will provide links relating to the bug itself so discussion on that front can happen elsewhere.
lofidevops
  • 21,912
How to run a command at login?:
Adding the command to the end of ~/.profile should do the trick (where ~ represents your home directory).
..you can start a script from a .desktop file in ~/.config/autostart/
OPTIONS -b --background run in background
sudo cpulimit -l 30 -b -p $(pgrep -o "unity-panel-service")
If you put a single & at the end of the command on a cli, it's supposed to run the job in the background. And it should find the new pid from the name every time. You can check if its running by:
pgrep -o "cpulimit"
Or create a bash script from it and make the script executable and set it to auto-run using autostart in Ubuntu.
alchemy
  • 850
