I am trying to Update my server
navin@ubuntu:~$ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
linux-image-generic : Depends: linux-image-3.2.0-67-generic but it is not installed
E: Unmet dependencies. Try using -f.
When i tried with the apt-get -f install
navin@ubuntu:~$ sudo apt-get -f install linux-image-3.2.0-67-generic
Suggested packages:
fdutils linux-doc-3.2.0 linux-source-3.2.0 linux-tools
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 29 not upgraded.
15 not fully installed or removed.
Need to get 0 B/38.8 MB of archives.
After this operation, 150 MB of additional disk space will be used.
(Reading database ... 147902 files and directories currently installed.)
Unpacking linux-image-3.2.0-67-generic (from .../linux-image-3.2.0-67-generic_3.2.0- 67.101_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.2.0-67-generic_3.2.0-   67.101_amd64.deb (--unpack):
failed in write on buffer copy for backend dpkg-deb during `./boot/vmlinuz-3.2.0-67-generic': No space left on device
No apport report written because MaxReports is reached already
                                                          dpkg-deb: error: subprocess   paste was killed by signal (Broken pipe)
  Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.2.0-67-generic /boot/vmlinuz-3.2.0-67-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.2.0-67-generic /boot/vmlinuz-3.2.0-67-generic
/var/cache/apt/archives/linux-image-3.2.0-67-generic_3.2.0-67.101_amd64.deb
When i tried to remove the clean out old kernel files in /boot
root@ubuntu: apt-get autoremove
Please provide some solution for this
That's the main problem:
It's your /boot partition that has no more space left. Try to do this:
Delete the unused kernel images manually. But, take care to not delete the used one or you will not be able to boot anymore. Type uname -r in a terminal. All that contains this version string must not be deleted.
When you cleaned the boot partition, use apt-get -f install linux-image-3.2.0-67-generic again.
Then update your system cleanly with:
chaos
  • 28,186
I think it's better to install Ubuntu tweak and remove old kernels through it.
It does it automatically for you.
You have to go to Janitor tab and select old kernel.
Then hit clean button and you are ready... :)
