I am facing problems with library dependencies when trying to install sphirewall-core. Is there any way to solve this or to install that dependencies?
These are the steps I followed:
$ sudo apt-get install sphirewall-core
Reading package lists... Done
Building dependency tree
 sphirewall-core : Depends: libboost-random1.49.0 (>= 1.49.0-1) but it is not installable
                   Depends: libboost-regex1.49.0 (>= 1.49.0-1) but it is not installable
                   Depends: libboost-serialization1.49.0 (>= 1.49.0-1) but it is not installable
                   Depends: libboost-system1.49.0 (>= 1.49.0-1) but it is not installable
                   Depends: libboost-thread1.49.0 (>= 1.49.0-1) but it is not installable
                   Depends: libprocps0 (>= 1:3.3.2-1) but it is not installable
                   Depends: libboost-random1.49-dev but it is not installable
Adaephon
  • 5,061
you can download sphirewall-core sourcecode from svn repository hosted by BitBucket Before that you need to install git on your system try this command on your terminal
sudo apt-get update
sudo apt-get install git
git clone https://bitbucket.org/sphirewalllabs/sphirewall-code.git
source http://sphirewall.net/
