I installed Skype on my nephew's new Ubuntu 14.04 LTS machine, and now we've decided to remove it. But I'm not able to locate it in my Installed programs section of Ubuntu Software Center. I'm able to call it up by opening the debian package, Software Center opens it up, but where I would normally see the "Remove" button, I have a "Reinstall" button. For the life of me, I can't figure out how to uninstall Skype. Any suggestions? In case you're wondering I used the version of Skype designed for 12.xx, as there was no option available for Ubuntu 14.xx.
My case is something different, here i run two commands :-
dpkg --get-selections | grep 'skype'
output is :- skype-bin:i386 install
So, to remove i run :-
sudo apt-get --purge remove skype-bin:i386
and after that i remove ".Skype" from home directory
- 956
To uninstall completely Skype from your system you just type the following line in Terminal:
sudo apt-get purge skype
And next time if you decide to install Skype again, follow How to install Skype 4.3
Sometimes just doing :
will not uninstall skype 4.3 version
Hence i would recommend doing :
sudo apt-get --purge remove skype:i386
and then going to home directory do "ctrl+H" and remove .skype folder...
- 231
This worked for me on Ubuntu 16.04.2 as of the date of this answer.
Remove package:
sudo apt remove skypeforlinux
Remove config:
rm -rf ~/.config/skypeforlinux
Remove repo:
sudo rm -v /etc/apt/sources.list.d/skype-*
- 939
Install and use Synaptic Package Manager, which you can find in Software Center to remove Skype. It is easy to manage installed/update/remove applications in this thing.
About Synaptic here - Synaptic Package Manager
This is how I removed skype
sudo apt-get --purge remove skypeforlinux
- 121
If you have installed your skype from official skype then it will be
If this not works then you need to check your skype name, run below command to check it :-
output is :- skypelinux install
If you have installed it from software centre then you can un-install it from there also.
- 121
I did the following pair of commands on Ubuntu 16.04.02 to get rid of Skype 4.3:
sudo apt-get autoremove
The first by itself still left a fully functional Skype installation. Autoremove took finished removing Skype without needing to manually delete any directories.
Edit:
The answers using skypeforlinux are for the newer versions of Skype (e.g. Skype 5.3).
- 11
