39
When I type a sudo command into the terminal it shows the following error:
sudo: /etc/sudoers is owned by uid 1000, should be 0
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
How do I fix this?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
6 Answers6
54
Change the owner back to root:
pkexec chown root:root /etc/sudoers /etc/sudoers.d -R
Or use the visudo command to ensure general correctness of the files:
pkexec visudo
αғsнιη
  • 36,350
muru
  • 207,228
Another option, in the case that one doesn't have the password for root or ubuntu users. I've fat-fingered ownership (more times than I want to admit) and ending up doing this:
sudo chown -R owner:group /
instead of this:
sudo chown -R owner:group .
This has almost always been in the context of a Vagrant-managed VirtualBox VM running Ubuntu headless, so YMMV. I'd never had a good fix until now, but this seems to do the trick easyishly.
Repair
  • Create or edit /etc/rc.local
    • NOTE Do this as vagrant user without trying to set permissions to root.
  • For this task, /etc/rc.local should look like this:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
chown -R root:root /etc/sudoers.d chown root:root /etc/sudoers chmod 440 /etc/sudoers
exit 0
  • Disconnect from SSH
  • Open VirtualBox Manager
  • Right-click VM in question
  • Select 'Close'=>'ACPI Shutdown'
  • Start the VM from the VirtualBox Manager by right-clicking the VM entry then selecting 'Start'=>'Normal Start'
  • SSH into VM
  • Use your now-restored sudo set permissions for children of / back to root:root
After the fix is in place the commands in /etc/rc.local can be removed.
AreDubya
  • 163
to recover from
sudo chown myuser:myuser /etc/sudoers
chmod u+w /etc/sudoers
chmod u-w /etc/sudoers
sudo chown root:root /etc/sudoers
The last of which results in the "sudo: /etc/sudoers is owned by uid 1000, should be 0", etc. errors. I tried to su - sudo which I've seen suggested but I don't think the root password was ever set so that did not work.¹
To fix this issue, I rebooted, dropped into a root shell and²
passwd root #for good measure, e.g., so su - root would work in the future!
Rebooted, voila.
NB: The pkexec commands suggested did not work for me while I was initially trying to fix the problem. After it was fixed via the recovery mode root shell, I subsequently tried it and a GUI window popped up asking for my password and it did work so YMMV.
¹ After fixing the problem, I repeated the steps and was able to recover with²
su - root
² The list of commands Rohlt suggests were unnecessary in my case but they might apply in other cases.
bvargo
  • 606
Here is what worked for me after all other failed.
Here is the original link to my steps https://metamug.com/article/networking/unable-to-access-sudoers-owned-by-uid-1000.html
Open two SSH sessions to the target server.
(Put both SSH side by side, so you can enter password at SSH-2 when running STEP-3,in SSH-1)
  1. In the first session, get the PID of bash by running:
echo $$
  1. In the second session, start the authentication agent with:
(Use the pid obtained from step 1)
pkttyagent --process 29824
  1. Back in the first session, run:
GOOD LUCK HOPE IT WORKS FOR YOU TOO!!!
sotirov
  • 4,379
if you have set and have the root password, first run the following command
$ su - root
it will ask for the root password and then run following commands one by one
chmod  755 /etc/sudoers.d
chmod  440 /etc/sudoers.d/*
bvargo
  • 606
Rohit
In my case, I was running Windows Subsystem for Linux(WSL2). I had created a folder using VSCode(running in windows) and opened it for creating more files in it.
After closing VSCode(which kept running in background), I tried deleting the created folder from WSL2 terminal and got the above error.
The solution was to terminate instance of VSCode fully(or restart system) as it was keeping the folder opened.
