I have a shell script in my Ubuntu Server 14.04 LTS at ./ShellScript.sh. I setup /etc/rc.local to run the shell script after boot but before login using below code.
To run run it boot write this command in terminal: sudo nano /etc/rc.local then add following and save.
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
#!/bin/bash
./ShellScript.sh
exit 0
Note: Keep in mind that I am working in root mode. Now when I run crontab -e then I got the following. Now What to do?
no crontab for root - using an empty one
Select an editor. To change later, run 'select-editor'.
1. /bin/ed
2. /bin/nano <---- easiest
3. /usr/bin/vim.basic
4. /usr/bin/vim.tiny
Choose 1-4 [2]:
After selecting 2, I got crontab: "/usr/bin/sensible-editor" exited with status 2
Now I want to run/execute this shell script again and again having 15min of time interval between every run after boot but before login. So Can I do it?
Answer:
First of all, you can't access crontab -e via root. You have to login via USER account. After login in USER account, Go to terminal and type crontab -e Here you will get some text like below.
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h dom mon dow command
Now I=in the end of file, you have to add */15 * * * * /ShellScript.sh line to run your script each after 15 min. Now save the file and its done.
Note: If you want different timing of interval to run script again and again then don't get confused. Here are some online tools that will generate Cron lines for you.
